[STATSGRASS] using R and gstat inside a C module
G. Allegri giohappy at gmail.com
Tue Oct 24 21:15:19 EDT 2006
Exactly that demo!
And this is the old page I was referring to:
http://193.84.38.2/~jachym/index.py?cat=pywps<http://193.84.38.2/%7Ejachym/index.py?cat=pywps>
The site is changing...
2006/10/25, Markus Neteler <neteler at itc.it>:
> Hi,
> demo to what...? Do you mean pywps or something else?
> If yes, why not leave a comment on that page?
> Do you mean this link:
> http://www.bnhelp.cz/mapserv/wpsdemo/
> Markus
> On Wed, Oct 25, 2006 at 12:22:36AM +0200, G. Allegri wrote:
> >    Well, I knew this link but a month ago it was in english and it
> contained
> >    a link to a demo too... Moreover it had a completely different
> layout. Was
> >    I dreaming?!!!
> >    2006/10/24, Markus Neteler < [1]neteler at itc.it>:
> >      On Tue, Oct 24, 2006 at 10:32:24AM +0200, G. Allegri wrote:
> >      >    As a result:
> >      >     - use R from shell scripitng
> >      >     - call, eventually, external programs using R system()
> function
> >      >     - make gis analysis through shell scripting
> >      >     - create a GUI with these solutions to be studied: the web
> way:
> >      pywps
> >      >    (HOPE MARKUS CAN GIVE ME SOME NEWS about it, I can't find the
> page
> >      >    anymore!!!), java(swig), php; wxpythn.
> >      Hi,
> >      which page can't you find? This one
> >      [2]http://les-ejk.cz/?cat=pywps
> >      cheers
> >      Markus
> >      _______________________________________________
> >      statsgrass mailing list
> >      [3]statsgrass at grass.itc.it
> >      [4]http://grass.itc.it/mailman/listinfo/statsgrass
> > References
> >    Visible links
> >    1. mailto:neteler at itc.it
> >    2. http://les-ejk.cz/?cat=pywps
> >    3. mailto:statsgrass at grass.itc.it
> >    4. http://grass.itc.it/mailman/listinfo/statsgrass
> Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
> ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18        -       38050 Povo (Trento), Italy
URL: http://lists.osgeo.org/pipermail/grass-stats/attachments/20061025/374b586f/attachment.html
More information about the grass-stats mailing list
