[STATSGRASS] problem with kriging not solved but new qestions arise
Jarek Jasiewicz jarekj at amu.edu.pl
Sat Sep 2 01:18:40 EDT 2006
Roger Bivand napisa?(a):
> On Fri, 1 Sep 2006, Jarek Jasiewicz wrote:
>> Jarek Jasiewicz napisa³(a):
>>> I try to krige some data, I do following grass wiki tutorial (that
>>> with gaiciture)
>> /cut
>>> with gaiciture)
>> /cut
>>  > And I recive the error:
>>  > Error in predict.gstat(g, newdata = newdata, block = block, nsim =
>> nsim,  :
>>  >  data items in gstat object and newdata have different coordinate
>>  > reference systems
>> After 20 hours of fighting with R I partially solved that problem
>> removing projection information (proj4) from both spatial data frames (I
>> set roj4string:Formal class 'CRS' [package "sp"] with 1 slots
>>   .. .. ..@ projargs: chr NA)
>> And all works well
>> so - projection information (EPSG 2173 - Polish, 1965 zone IV) makes
>> problem?
>>  why?
>> or eny projection makes problem - in fact, tutorial data has no proj4
>> information
> This has just bitten me too!
> predict.gstat() tries to be fussy and check that the projections are
> equal, but they are not always represented the same way even though they
> are the same. In my case for Meuse bank I had:
>> proj4string(BMcD_grid)
> [1] "+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889 +k=0.999908 +x_0=155000 +y_0=463000 +no_defs +a=6377397.155
> +rf=299.1528128 +towgs84=565.036,49.914,465.839,-0.4094,0.3597,-1.86854,-4.0772"
>> proj4string(BMcD)
> [1] "+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889 +k=0.999908 +x_0=155000 +y_0=463000 +ellps=bessel +units=m +no_defs"
> So I simply assigned from one to the other to have the same
> representation before calling gstat():
>> proj4string(BMcD) <- CRS(proj4string(BMcD_grid))
> I hope the same will work for you.
> Roger
>> mayby sombody know???
>>  regards
>> Jarek
>> statsgrass mailing list
>> statsgrass at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/statsgrass
Yes, work!
thanks a lot
Jarek
More information about the grass-stats mailing list
