[STATSGRASS] kriging, fit.variogram - negative range, S-JTSK
Tomas Lanczos lanczos at t-zones.sk
Tue Aug 14 17:32:31 EDT 2007
I constructed a variogram for spatial data in S-JTSK, following a
procedure like here: http://casoilresource.lawr.ucdavis.edu/drupal/node/438
When I am trying to fit a variogram spherical or exponential model I am
getting an error message about negative range. I have a suspicion that
it is because in S-JTSK we are using negative vaules for coordinates,
even I don't see any reason why could it be a problem ... am I right? If
not, what can be the reason?
Thanks a lot in advance
Tomas
More information about the grass-stats mailing list
