[STATSGRASS] import DTM with readRAST6()
Matteo Dall'Amico matteo.dallamico at ing.unitn.it
Mon Jul 9 10:29:50 EDT 2007
Hi Carlos,
thank you for your reply.
I think the problem is that the import was not successful. As you see
from data attributes,
Data attributes:
DTM_trentino_100m
Min.   :1.192e-319
1st Qu.:1.065e-314
Median :1.066e-314
Mean   :1.285e-312
3rd Qu.:2.722e-312
Max.   :4.774e-312
the elevations are not correct. I would expect values ranging between
60 and 3500m and not from 1.192e-319 to 4.774e-312.
I think the problem lays in the import procedure during readRAST6().
Any suggestion?
Thanks in advance,
Matteo
On 9 Jul 2007, at 15:41, Carlos Guâno Grohmann wrote:
> try to
> str(trentino.grid)
> the summary() you want is probably
> summary(trentino.grid$DTM_trentino_100m)
> hope this helps
> Carlos
> On 7/9/07, Matteo Dall'Amico <matteo.dallamico at ing.unitn.it> wrote:
>> Hello everybody,
>> I am a new R & Grass user.
>> I am interested in doing a kriging of the Temperature in a basin,
>> based on
>> pixel elevation (DTM).
>> I use Grass 6.2.1 and R 2.5.1 and have installed the spgrass6
>> package.
>> The DTM is called "DTM_trentino_100m" and has a header and data
>> like the
>> following:
>> north:5158000.0
>> south:5058500.0
>> east:1729700.0
>> west:1611600.0
>> rows:995
>> cols:1181
>> -9999.0 -9999.0 -9999.0 370.84381103515625 372.55120849609375
>> 373.13128662109375 .....
>> I have opened R inside the Grass location, and imported the DTM:
>> >  trentino.grid<-readRAST6("DTM_trentino_100m")
>> Creating BIL support files ...
>> Header File =
>> /Users/Matteo/Documents/DataGrass/GBovest/Permafrost/.tmp/
>> nilo.local/DTM_trentino_100m.hdr
>> World File =
>> nilo.local/DTM_trentino_100m.wld
>> Exporting Raster as double values(bytes=8)
>> Using the Current Region settings ...
>> north=5158000.000000
>> south=5058500.000000
>> east=1729700.000000
>> west=1611600.000000
>> r=995
>> c=1181
>> Percent complete:  100%
>> r.out.bin complete.
>> > summary(trentino.grid)
>> Object of class SpatialGridDataFrame
>> Coordinates:
>>               min     max
>> coords.x1 1611600 1729700
>> coords.x2 5058500 5158000
>> Is projected: TRUE
>> proj4string :
>> [+proj=tmerc +lat_0=0.0000000000 +lon_0=9.0000000000
>> +k_0=0.9996000000
>> +x_0=1500000.0000000000 +y_0=0.0000000000 +a=6378388 +rf=297 +no_defs
>> +towgs84=-225.000,-65.000,9.000]
>> Number of points: 2
>> Grid attributes:
>>   cellcentre.offset cellsize cells.dim
>> 1           1611650      100      1181
>> 2           5058550      100       995
>> Data attributes:
>> DTM_trentino_100m
>> Min.   :1.192e-319
>> 1st Qu.:1.065e-314
>> Median :1.066e-314
>> Mean   :1.285e-312
>> 3rd Qu.:2.722e-312
>> Max.   :4.774e-312
>> As you can see, the import has been fully done, yet the attributes
>> are not
>> correct. In fact, the Min. value is 1.192e-319 and the Max is
>> 4.774e-312 but
>> in reality the elevation changes between 60m to 3500m.
>> Have I done something wrong? What should I do?
>> Thank you in advance,
>> Matteo
>> Matteo Dall'Amico
>> PhD candidate
>> CUDAM and department of Civil and Environmental Engineering
>> Universita' degli Studi di Trento
>> Via Mesiano 77 - 38050 Trento - Italy
>> email: matteo.dallamico at ing.unitn.it
>> Tel. +39 0461 882610
>> Fax +39 0461 882672
>> http://www.dottorato.it/trento/
>> statsgrass mailing list
>> statsgrass at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/statsgrass
>              Carlos Henrique Grohmann - Guano
>  Visiting Researcher at Kingston University London - UK
>  Geologist M.Sc  - Doctorate Student at IGc-USP - Brazil
> Linux User #89721  - carlos dot grohmann at gmail dot com
> _________________
> "Good morning, doctors. I have taken the liberty of removing Windows
> 95 from my hard drive."
> --The winning entry in a "What were HAL's first words" contest judged
> by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
More information about the grass-stats mailing list
