[STATSGRASS] GRASS+R: problem with gmeta() command
pierluigi de rosa sisma66 at tiscali.it
Wed Jul 25 07:50:46 EDT 2007
Did you run library(spgrass6)?
If yes, you should have gmeta6()!.
Bye
Pierluigi
Alle 13:17, mercoledì 25 luglio 2007, Mauricio Zambrano ha scritto:
> Hi,
> I'm using GRASS 6.2.2cvs and R 2.4.1, and I'm new in the use of R.
> I installed the package GRASS within R (and all the Spatial and
> Machine Learning & Statistical Learning packages) without any
> problems, but when I loaded the package GRASS into R (inside
> GRASS-GIS) and I put the command "gmeta()", I obtained the error
> message "Bad or no region for current mapset". However I can see the
> limits for my region within GRASS-GIS and when I put the command
> "g.region -p" within GRASS-GIS, I obtain:
> projection: 1 (UTM)
> zone:       -19
> datum:      psad56
> ellipsoid:  international
> north:      6456369.99999
> south:      6205510
> west:       237658
> east:       428666.999996
> nsres:      25.00099661
> ewres:      25.00117801
> rows:       10034
> cols:       7640
> cells:      76659760
> any help in how to solve this problem with "gmeta()" command will be
> very valuable for me
> Thanks in advance
> Mauricio Zambrano B.
> (University of Trento)
> statsgrass mailing list
> statsgrass at grass.itc.it
> http://grass.itc.it/mailman/listinfo/statsgrass
More information about the grass-stats mailing list
