[STATSGRASS] moving-window analysis
Carlos "Guâno" Grohmann carlos.grohmann at gmail.com
Wed Jun 6 16:07:44 EDT 2007
I guess it's something like that. this is what I did:
after importing a DEM from GRASS, creating a mask etc:
x <- krige(S25W049 ~ 1, locations=srtm, newdata=mask, nmax=24)
> summary(x)
Object of class SpatialPixelsDataFrame
Coordinates:
       min     max
s1  719500  776650
s2 7260800 7300400
Is projected: TRUE
proj4string :
[+proj=utm +south +zone=22 +a=6378160 +rf=298.25 +no_defs
+towgs84=-60.0,-2.0,-41.0 +to_meter=1.0]
Number of points: 279400
Data attributes:
   var1.pred          var1.var
 Min.   :  33.73   Min.   :    NA
 1st Qu.: 236.77   1st Qu.:    NA
 Median : 434.94   Median :    NA
 Mean   : 471.73   Mean   :   NaN
 3rd Qu.: 685.39   3rd Qu.:    NA
 Max.   :1186.84   Max.   :    NA
                   NA's   :279400
So I have the var1.pred, which is basically my original DEM, and
var1.var is all NA's..
What I want, is that the pixel final value to be equal to the
deviation of that pixel original value about the best-fit plane
calculated over the points in the moving window (8, 24..).
thanks
On 6/6/07, Edzer J. Pebesma <e.pebesma at geo.uu.nl> wrote:
> Well, package gstat provides linear regression within a local search
> neighbourhood defined either by distance (circular window) or by nr of
> nearest neighbours. Is that what you want?
> try:
> library(gstat)
> data(meuse)
> data(meuse.grid)
> coordinates(meuse)=~x+y
> gridded(meuse.grid) = ~x+y
> x = krige(log(zinc)~sqrt(dist),meuse,meuse.grid,maxdist=600)
> image(x)
> Edzer
> Carlos "Guâno" Grohmann wrote:
> > Basic moving-window (ie, mean, stddev etc) is easy. The tricky
> > question is how to make a best-fit least squares inside that moving
> > window? I mean that it has to be a general function, so you can choose
> > the size of the window.
> > Carlos
> > On 6/6/07, G. Allegri <giohappy at gmail.com> wrote:
> >> In my experience the easier way to realize a moving-window analysys
> >> between rasters is to use r.mapcalc. I never did it in R. I knew that
> >> caTools package could do it someway... but I think using r.mapcla is
> >> more straightforward.
> >> Look at this nice article:
> >> http://casoilresource.lawr.ucdavis.edu/drupal/node/221
> >> Giovanni
> >> 2007/6/6, Carlos Guâno Grohmann <carlos.grohmann at gmail.com>:
> >> > > What kind of data do you have?
> >> > DEMs, some LiDAR, maybe
> >> > > > Hello. I was thinking what would be the best way to do a
> >> moving-window
> >> > > > analysis where the result is the deviation of values about a
> >> best-fit
> >> > > > plane?
> >> > > > some modification to r.in.xyz?
> >> > > > r.mapcalc?
> >> > > > R? (which package, function..?)
> >> > > > thanks
> >> > > >               Carlos Henrique Grohmann - Guano
> >> > > >   Visiting Researcher at Kingston University London - UK
> >> > > >   Geologist M.Sc  - Doctorate Student at IGc-USP - Brazil
> >> > > > Linux User #89721  - carlos dot grohmann at gmail dot com
> >> > > > _________________
> >> > > > "Good morning, doctors. I have taken the liberty of removing
> >> Windows
> >> > > > 95 from my hard drive."
> >> > > > --The winning entry in a "What were HAL's first words" contest
> >> judged
> >> > > > by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
> >> > > > _______________________________________________
> >> > > > statsgrass mailing list
> >> > > > statsgrass at grass.itc.it
> >> > > > http://grass.itc.it/mailman/listinfo/statsgrass
> >> > _________________
> >> > "Good morning, doctors. I have taken the liberty of removing Windows
> >> > --The winning entry in a "What were HAL's first words" contest judged
_________________
More information about the grass-stats mailing list
