[STATSGRASS] moving-window analysis
Thu Jun 7 04:49:19 EDT 2007
Carlos wrote:
> Basic moving-window (ie, mean, stddev etc) is easy. The tricky
> question is how to make a best-fit least squares inside that moving
> window? I mean that it has to be a general function, so you can choose
> the size of the window.
just for simple stuff, but within GRASS, you could look at r.neighbors
and r.mfilter.
perhaps you could write a new method to use with r.neighbors?
or use r.mapcalc/r.series to create a map containing the difference
between the original and the r.neighbors smoothed version?
Hamish
More information about the grass-stats mailing list
