[GRASS-stats] readVECT6 problem fo importing null data
Jarosław Jasiewicz jarekj at amu.edu.pl
Tue Nov 27 07:03:00 EST 2007
Roger Bivand pisze:
> On Mon, 26 Nov 2007, Jarek Jasiewicz wrote:
>> Dear Collages!
>> I found some Issue (seems problematic) with readVECT6 (there are all
>> commands I used, complete my answer)
>> I have vector file attached table (pgSQL) with null values both for
>> int4 and char columns (example table):
>> I import the table via RdbiPgSQL
> Dear Jarek,
> Could you please try readOGR() directly from the PostgreSQL/PostGIS
> source? This will remove the imposition of the intermediary DBF
> format, and if it succeeds provides a feasible solution, and if it
> doesn't, suggests that OGR drivers have problems with missing value
> handling in some implementations (in GRASS and in rgdal, where
> v.in.ogr and readOGR() use the same basic approach, as do v.out.ogr
> and writeOGR()).
> Roger
So the problem is in r.out.ogr?. There are some other methods as you
describe. So I solved problem easyly. I rather point out issue, maybe
for some other R and GRASS users.
Best ragards
Jarek
More information about the grass-stats mailing list
