[GRASS-stats] Reclassyify in R
Jarosław Jasiewicz jarekj at amu.edu.pl
Thu Nov 29 03:47:47 EST 2007
Dear all.
Working on my problem I stopped on another issue.
I try to reclassify SpatialGridDataFrame acording to vector file:
let say:
- slope imported from GRASS (sp_layer, numeric vector from
SpGridDataFrame  slope$slope)
-density obiect made in R (iloraz_obiect, with density$x with ald values
and density$y with new vlues)
And I have very primitive (step by step) solution:
reclass<-function(sp_layer,dens_iloraz_object) {
tmp_k<-0
layer_length<-length(sp_layer) #number of values in reclasified vector,
about million
dens_length<-length(dens_iloraz_object$x) #number of class of reclassify
for (i in seq(1:layer_length)) {  #loop for million iteration
    if (is.na(sp_layer[i])) tmp_k[i]<-NA else { #test if there is NA value
        if (sp_layer[i]==dens_iloraz_object$x[dens_length]) #test if it
is max and last value of recllsifying vector
            {tmp_k[i]<-dens_iloraz_object$y[dens_length] } else {
                for (j in seq(1:(dens_length-1))) { #reclasify according
rules loop about 32 or 64 rules
                if (!is.na(tmp_k[i])) break #if done! break!
                    if (sp_layer[i]>=dens_iloraz_object$x[j] &
sp_layer[i]<dens_iloraz_object$x[j+1]) tmp_k[i]<-dens_iloraz_object$y[j]
return (tmp_k)
} #end funcion
What is the problem If works?      it is komputer killer.
I have solution which seems faster:
tmp_k<-NA
    if (sp_layer==dens_iloraz_object$x[dens_length])
{tmp_k<-dens_iloraz_object$y[dens_length] } else {
            if (!is.na(tmp_k)) break
                if (sp_layer>=dens_iloraz_object$x[j] &
sp_layer<dens_iloraz_object$x[j+1]) tmp_k<-dens_iloraz_object$y[j]
return (tmp_k)
 and next:
k=ifelse(is.na(sp_layer),NA,reclass(sp_layer,iloraz_dens))
but I cannot handle if (sp_layer==......) in function, which proceeds on
vector and use only first element
I look for little faster solution
Maybe someone can help me?
Jarek
More information about the grass-stats mailing list
