[STATSGRASS] sp_0.9-16 source on CRAN
Roger Bivand Roger.Bivand at nhh.no
Tue Oct 16 06:49:57 EDT 2007
On Tue, 16 Oct 2007, Rainer M Krug wrote:
> Hi Roger
> first of all thanks a lot for your prompt reply. I tried it with two other
> raster layers, and one worked.
> I played around, and the problem seems top be the length of the output
> variable:
> GRASS 6.2.2 (grass):~/Documents/Projects/AlienSpread/R > r.out.bin -b
> input=Hakea_dc_2007
> output=/home/rkrug/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
> null=-1
> Creating BIL support files ...
> Header File = eeeeee.wld          <<<<<<------HERE IT IS NOT
> World File =
> /home/rkrug/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee.wld
> Exporting Raster as integer values (bytes=2)
> Using the Current Region settings ...
> north=6247000.000000
> south=6195000.000000
> east=270200.000000
> west=251000.000000
> r=520
> c=192
> Percent complete:  100%
> r.out.bin complete.
> [Raster MASK present]
> GRASS 6.2.2 (grass):~/Documents/Projects/AlienSpread/R > ll /home/rkrug/eee*
> -rw-r--r-- 1 rkrug users 199680 2007-10-16 12:18
> -rw-r--r-- 1 rkrug users     60 2007-10-16 12:18
> input=Hakea_dc_2007
> null=-1
> Header File =
> /home/rkrug/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee.hdr
> World File =
> /home/rkrug/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee.wld
> east=270200.000000
> west=251000.000000
> r=520
> c=192
> r.out.bin complete.
> -rw-r--r-- 1 rkrug users     83 2007-10-16 12:18
> So it is a problem in grass itself.
> I should be able to find a way around, but I should file a bug report.
Yes, I should have remembered that something like it did come up before. I
can see email traffic from July this year, thread here:
http://grass.itc.it/pipermail/statsgrass/2007-July/000619.html
So it is fixed in CVS for 6.3 and in CVS for 6.2.3.
Roger
> Thanks a million,
> Rainer
> Roger Bivand wrote:
>>  On Tue, 16 Oct 2007, Rainer M. Krug wrote:
>> >  Hi
>> >  I just upgraded to the new version, and I get an error message when
>> >  importing an existing raster. The output is below.
>>  This is not related to the sp update. Please do debug(readRAST6) and
>>  re-run, stepping through until you pass the the setting of the command
>>  string for r.out.bin. Please then print the cmd variable to screen and
> debug: tull <- ifelse(.Platform$OS.type == "windows", system(cmd),
> system(cmd,
>    ignore.stderr = ignore.stderr))
> Browse[1]> cmd
> [1] "r.out.bin -b input=Hakea_seeds_2007
> output=/home/rkrug/Documents/Projects/AlienSpread/R/../grass/simulation/.tmp/rkrug-linux/Hakea_seeds_2007
> null=-1"
> Browse[1]>
>>  copy&paste it. It should have a -b flag. Please also give the output of
>>  sessionInfo() for your system, and the output of system("g.version") too.
>>  sessionInfo()
> R version 2.6.0 (2007-10-03)
> i686-pc-linux-gnu
> locale:
> LC_CTYPE=en_GB.UTF-8;LC_NUMERIC=C;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB.UTF-8;LC_MONETARY=en_GB.UTF-8;LC_MESSAGES=en_GB.UTF-8;LC_PAPER=en_GB.UTF-8;LC_NAME=C;LC_ADDRESS=C;LC_TELEPHONE=C;LC_MEASUREMENT=en_GB.UTF-8;LC_IDENTIFICATION=C
> attached base packages:
> [1] stats     graphics  grDevices utils     datasets  methods   base
> other attached packages:
> [1] gstat_0.9-40    spgrass6_0.4-3  maptools_0.6-17 rgdal_0.5-15
> [5] sp_0.9-16       foreign_0.8-23
> loaded via a namespace (and not attached):
> [1] grid_2.6.0     lattice_0.16-5
>>  system("g.version")
> GRASS 6.2.2 (2007)
>>  The *.wld file got put in the correct place, so the *.hdr ought to have
>>  been there too.
>>  If you do debug(readBinGrid), you'll see where it fails now, about 4 lines
>>  in. You could also do list.files(dirname(fname)) just before it fails in
>>  readBinGrid(), to check whether there ia anything else odd going on. Have
>>  you checked to see whether it has been written anywhere else?
>>  Roger
>> > >   readRAST6("Hakea_seeds_2007")
>> >  Header File = ld
>> >  World File =
>> >  /home/rkrug/Documents/Projects/AlienSpread/R/../grass/simulation/.tmp/rkrug-linux/Hakea_seeds_2007.wld
>> >  Exporting Raster as double values(bytes=8)
>> >  east=270200.000000
>> >  west=251000.000000
>> >  r=520
>> >  c=192
>> >  Percent complete:
>> >  r.out.bin complete.
>> >  Error in readBinGrid(rtmpfl11, colname = vname[i], proj4string = p4,
>> >  integer = to_int) :
>> >  no such file:
>> >  /home/rkrug/Documents/Projects/AlienSpread/R/../grass/simulation/.tmp/rkrug-linux/Hakea_seeds_2007.hdr
>> >  The contents of the folder are as follow:
>> >  (grass):~/Documents/Projects/AlienSpread/grass/simulation/.tmp/rkrug-linux
>> > >   ll Hakea*
>> >  -rw-r--r-- 1 rkrug users 798720 2007-10-16 11:10 Hakea_seeds_2007
>> >  -rw-r--r-- 1 rkrug users     60 2007-10-16 11:10 Hakea_seeds_2007.wld
>> >  -rw-r--r-- 1 rkrug users 798720 2007-10-16 10:52
>> >  Hakea_seedsDispersed_2007
>> >  -rw-r--r-- 1 rkrug users     60 2007-10-16 10:52
>> >  Hakea_seedsDispersed_2007.wld
>> >  GRASS 6.2.2
>> >  Is there something wrong in my paths or os there a bug?
>> >  Thanks a lot,
>> >  Rainer
>> >  Roger Bivand wrote:
>> > >  A new version of the foundation sp package is reaching CRAN mirrors,
>> > >  and
>> > >   Windows and OSX binaries should follow within a day or so. There is a
>> > >   significant change in how SpatialGrid objects are created, which we
>> > >  hope
>> > >   will not affect users negatively, and which is giving a two orders of
>> > >   magnitude speedup for reading larger rasters (single band 900 by
>> > >  3600 down
>> > >   from 12 minutes to 6 seconds on an older 1.5GHz machine).
>> > >   If anyone sees any negative impacts, please contact the authors
>> > >   immediately directly.
>> > >   Roger
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
