[STATSGRASS] Re: spgrass6 compile problem
Roger Bivand Roger.Bivand at nhh.no
Tue Oct 16 12:09:23 EDT 2007
On Tue, 16 Oct 2007, Thomas Adams wrote:
> Roger,
> I am trying to compile spgrass6 on a Linux system with R 2.6.0. I have
> compiled all the dependencies without problems, but I am getting:
> xt4-tir:adams> R CMD INSTALL spgrass6_0.4-3.tar.gz
> * Installing to library '/awips/rep/lx/local_apps/R.dir/lib/R/library'
> * Installing *source* package 'spgrass6' ...
> ** R
> ** inst
> ** preparing package for lazy loading
> Loading required package: sp
> Loading required package: maptools
> Loading required package: foreign
> Loading required package: rgdal
> Error in dyn.load(file, ...) :
> unable to load shared library
> '/awips/rep/lx/local_apps/R.dir/lib/R/library/rgdal/libs/rgdal.so':
> /awips/hydro/lx/gcc_shlibs/libgcc_s.so.1: version `GCC_3.3' not found
> (required by /usr/lib/libstdc++.so.6)
> Error: package 'rgdal' could not be loaded
> Execution halted
> ERROR: lazy loading failed for package 'spgrass6'
> ** Removing '/awips/rep/lx/local_apps/R.dir/lib/R/library/spgrass6'
> ** Restoring previous '/awips/rep/lx/local_apps/R.dir/lib/R/library/spgrass6'
> I don't understand this:
> Do you have any insights? I have previously compiled spgrass6 without
> problems. But we have had some system changes since that time. System
> requirements force me to install in a non-standard location.
What happens if you start R, say library(rgdal), and try to do - say -
example(readGDAL)? If the same happens, then most likely rgdal was
installed before the system upgrade, and you now have g++4, meaning that
the dependencies of rgdal (or GDAL as a whole) are no longer met.
If library(rgdal) fails as I suspect, you'll need to re-install it:
install.packages("rgdal")
ought to be enough, though GDAL may also need to be re-installed (all C++
programs are sensitive to build train upgrades, much more so than C
programs). You may also do
update.packages(checkBuilt=TRUE)
which will freshen all the installed packages built with R < 2.6.
If rgdal itself works, then sorry, no idea. Maybe somebody on the list
(STATGRASS, R-sig-geo) may have seen something similar. How were R and
GDAL installed, from source? What does g++ -v say?
Roger
> Regards,
> Tom
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
