[STATSGRASS] v.stats.rast for category raster or vector cross statistics
Matthew Perry perrygeo at gmail.com
Mon Oct 22 11:22:18 EDT 2007
Agustin,
I would suggest taking a look at starspan
(http://starspan.casil.ucdavis.edu/). It specializes in
vector-on-raster analyses and has a --count-by-class flag for
categorical rasters. I wrote a bit more about it at
http://www.perrygeo.net/wordpress/?p=30 .
- matt
 On 10/22/07, Agustin Lobo <Agustin.Lobo at ija.csic.es> wrote:
> Dear lists,
> Given Av (vector of polygons) and Br (raster of a categorical variable,
> i.e. a classification or a soil map) I want to calculate
> for each polygon in Av, the surface of each category from Br.
> v.stats.rast almost does it, but calculates lumped stats for each
> polygon (i.e, assumes that Br is a continuous variable).
> Alternatively, I could have Br as another vector Bv, but don't find
> the way of calculating cross stats as r.stats -a in=Ar,Br would do for
> raster layers.
> Converting Av into raster Ar is inconvenient, as the polygons are few
> and small and would have to use a very samll cell size (Br is large)
> Any easier way through R?
> Dr. Agustin Lobo
> Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
> LLuis Sole Sabaris s/n
> 08028 Barcelona
> Spain
> Tel. 34 934095410
> Fax. 34 934110012
> email: Agustin.Lobo at ija.csic.es
> http://www.ija.csic.es/gt/obster
> statsgrass mailing list
> statsgrass at grass.itc.it
> http://grass.itc.it/mailman/listinfo/statsgrass
Matthew T. Perry
"Never ascribe to malice, that which can be adequately explained by
incompetence."
More information about the grass-stats mailing list
