[STATSGRASS] problems with installing maptools package (due to Foreign package)
Wed Oct 31 18:39:32 EDT 2007
> G. Allegri wrote:
> > The problem has come with maptools setup which har raised an error
> > when trying to load "foreign" package for lazy loading. The exit error
> > said
> > "This is R 2.5.1, package 'foreing' needs >= 2.6.0"
Daniel McInerney wrote:
> The current version of foreign on CRAN is 0.8-23,
> which depends on R >= 2.6.0
> You could try and install a previous version of
> foreign either (0.8-22 or 0.8-21) available under
> the Archived Packages on the cran.r-project website.
> If you don't want to compile R 2.6, you could add
> the sid repository to your apt-sources. You should be
> able to safely build for lenny using the sid sources.
R 2.6.0 should arrive in testing in the next day or few,
  http://packages.qa.debian.org/r/r-base.html
I hope there is a good reason for the version dep (which there well may be), as
it is very annoying when things are not backwards compatible for trival
reasons. Not everyone is running or wants to run the latest Gentoo.
Hamish
__________________________________________________
Do You Yahoo!?
Tired of spam?  Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
More information about the grass-stats mailing list
