[STATSGRASS] kriging - too long time
Edzer J. Pebesma e.pebesma at geo.uu.nl
Sun Sep 2 07:37:21 EDT 2007
That might be "explained" as follows: 8 to 400 is a factor 25, solving a
covariance matrix is an O(N^2) operation so would slow down by a factor
25*25 = 625. The remaining factor 6 (seconds to hours: 3600/625) should
be attributable to the load of finding the nearest 400 neighbours
instead of 8 nearest neighbours. I don't know that behaviour (a
bucket-PR quadtree search index is used), but am not surprised.
Best wishes,
Edzer
Carlos "Guâno" Grohmann wrote:
> Tomas,
> nmax has a strong influence on kriging time. In some tests I've done,
> interpolation time for and area with 520 rows x 430 cols ranged from
> about 20 seconds for nmax=8 up to 20 HOURS for nmax =399.
> best
> Carlos
> On 9/2/07, Tomas Lanczos <lanczos at t-zones.sk> wrote:
>> I am performing some kriging following the procedure as it is here:
>> http://casoilresource.lawr.ucdavis.edu/drupal/node/438
>> My problem is that the kriging proces is very slow, it takes approx. 7
>> hours. Is the problem a too high resolution, or too much sampling points
>> (2234)? How can I optimalize the process?
>> My region setup is the following:
>> projection: 1 (UTM)
>> zone:       33
>> datum:      ** unknown (default: WGS84) **
>> ellipsoid:  bessel
>> north:      5387295.0553002
>> south:      5288130.42061478
>> west:       652025.98376024
>> east:       786301.92841404
>> nsres:      150.02214022
>> ewres:      150.02898844
>> rows:       661
>> cols:       895
>> cells:      591595
>> Many thanks
>> Tomas
>> statsgrass mailing list
>> statsgrass at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/statsgrass
More information about the grass-stats mailing list
