[GRASS-stats] Speedup of readVECT6() with plugin
Markus Neteler neteler at osgeo.org
Sat May 31 06:36:29 EDT 2008
Dear Roger, all,
I have to read in Lidar data from GRASS, so speed matters. I have
modified the readVECT6() function to not export to SHAPE but
read in directly via GRASS-GDAL/OGR plugin:
# original, via SHAPE:
> system("date")
Sat May 31 12:17:05 CEST 2008
> lidar1 <- readVECT6("lidar1map3d", ignore.stderr=TRUE)
> system("date")
Sat May 31 12:28:33 CEST 2008
# simplified version using plugin:
> system("date")
> lidar1 <- myreadVECT6("lidar1map3d", ignore.stderr=TRUE)
> system("date")
Sat May 31 12:29:26 CEST 2008
I used directly readOGR():
# hack:
    res <- readOGR(dsn =
"/home/neteler/grassdata/eth_utm32/PERMANENT/vector/lidar1map3d/head",
layer = "1", verbose = !ignore.stderr)
Would it be possible to use this approach if the plugin
is present, otherwise fallback to SHAPE export as before?
Thanks
Markus
More information about the grass-stats mailing list
