[GRASS-stats] Speedup of readVECT6() with plugin
Markus Neteler neteler at osgeo.org
Sat May 31 12:47:10 EDT 2008
On Sat, May 31, 2008 at 6:35 PM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
> On Sat, 31 May 2008, Markus Neteler wrote:
>> On Sat, May 31, 2008 at 5:51 PM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>>>> I have to read in Lidar data from GRASS, so speed matters. I have
>>>> modified the readVECT6() function to not export to SHAPE but
>>>> read in directly via GRASS-GDAL/OGR plugin:
>>> Dear Markus,
>>> In theory maybe, but if I cannot make the plugin work (I use SELinux on
>>> F7 for trials, and I have not found out how to make it accept the *.so from
>>> GRASS), then I don't think that it is going to be very helpful.
>> Sure. but I can help you if you like (got it running on various kinds of
>> machines). It's also documented:
>> http://grass.osgeo.org/wiki/Compile_and_install_GRASS_and_QGIS_with_GDAL/OGR_Plugin
> Including machines with SELinux running? It is very picky with ldconfig.
I have never tried SELinux.
But I simply use:
cat /etc/ld.so.conf.d/grass.conf
/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/lib
(so I don't even run "make install" but use GRASS from
my home)
> Aha, I've been compiling with GRASS support, which was the old way. I'll try
> again.
thanks and good luck,
Markus
More information about the grass-stats mailing list
