[GRASS-stats] spgrass problem importing category 999 when plugin is FALSE
Jarek Jasiewicz jarekj at amu.edu.pl
Fri Apr 3 01:19:01 EDT 2009
Hi
I during batch processing of couple of maps I found strange behaviour of
readRAST6 when I import cell map with value 999.
Instead of 999 Na is imported (?? _
It is for me completely strange, so I test it with folowing:
echo "test_map=999"|r.mapclac
R
library(spgrass6)
testNoPlugin=readRAST6("test_map",plugin=FALSE)
summary(testNoPlugin at data)
     test      Min.   :    NA 1st Qu.:    NA Median :    NA Mean   :
NaN 3rd Qu.:    NA Max.   :    NA NA's   :156740
testPlugin=readRAST6("test_map",plugin=TRUE)
summary(testPlugin at data)
     test   Min.   :999 1st Qu.:999 Median :999 Mean   :999 3rd Qu.:999
Max.   :999
It is very strange for me but I tested it on several maps. I think
someone could try to reproduce this.
Jarek
BTW:
R version 2.8.1 (2008-12-22)
library(spgrass6)
Loading required package: sp
Loading required package: rgdal
Geospatial Data Abstraction Library extensions to R successfully loaded
Loaded GDAL runtime: GDAL 1.5.3, released 2008/09/09
GDAL_DATA: /usr/local/lib/R/site-library/rgdal/gdal
Loaded PROJ.4 runtime: Rel. 4.6.1, 21 August 2008
PROJ_LIB: /usr/local/lib/R/site-library/rgdal/proj
GRASS GIS interface loaded with GRASS version: 6.5.svn
and location: Rzeki
Package: spgrass6
Version: 0.5-16
Date: 2008-11-13
Built: R 2.8.1; ; 2009-01-02 14:02:31; unix
More information about the grass-stats mailing list
