[GRASS-stats] "all-directional" r.texture
Agustin Lobo alobolistas at gmail.com
Fri Apr 17 06:56:34 EDT 2009
Hi!
Is there any way to get r.texture to ignore directions? That is,
according to the
help page, you get one result for each statistic and for each direction,
which implies
that the co-occurence matrix is calculated for each direction. I'm not
interested on
directions, so I require just one co-occurrence matrix calculated for
all directions.
Note that, while the 4 co-occurrence matrices can be added up to create the
"all directions" co-occurrence matrix, results from directional
cannot be added up or averaged  (i.e.,  the "all directional" entropy is
not the average
entropy for 0,45,135,90).
I'm suspecting that modifying the code will be required, but just want
to make
sure that the "all directional" option is really lacking (may be this is
just a documentation
problem).
Thanks
Agus
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-stats/attachments/20090417/de8b21e7/alobolistas.vcf
More information about the grass-stats mailing list
