[GRASS-stats] Raster maps from GRASS to R and back to GRASS?
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Tue Apr 21 18:58:23 EDT 2009
Thank you very much for your time Roger :-)
Nikos:
> >  I can't "solve" the random-NULL production of writeRAST6. I tried
> > again with only 3 bands which are identical with respect to their
> > extent/resolution/etc.
Roger:
> The NAs you show in the fake2 image are in band 7 (b7) and propagate
> correctly, b7 shown after import to R;
Right: _after_ import to R. They are just _999_ values prior importing
in R.
> They are getting there because the NODATA= argument is not given, and is
> being set to 999. I've committed a fix to sourceforge CVS, but setting
> NODATA= manually is generally a good idea.
But why is "NODATA=" set to 999? It's a bug, right?
# reading the help page of readRAST6()
?readRAST6
NODATA: by default NULL, in which case it is set to one less than
          'floor()'of the data values, otherwise an integer NODATA
          value (required to be integer by GRASS r.out.bin)
Kindest regards, Nikos
> > References
> > [1] grass location containint three MODIS surface reflectance bands:
> > https://git.berlios.de/cgi-bin/gitweb.cgi?p=gregis;a=blob_plain;f=peloponnesos/modis_peloponnese_postfire07.zip;hb=peloponnese
> > [2] http://imageshack.gr/view.php?file=owj2xu833u6678c3zvch.png
> > [3] http://imageshack.gr/view.php?file=n65vfvoo07t3njywfjjo.png
> > [4] http://imageshack.gr/view.php?file=sb9l315wazoeue0rgrj9.png
More information about the grass-stats mailing list
