[GRASS-stats] Re: spgrass6 and initGRASS
Roger Bivand Roger.Bivand at nhh.no
Mon Dec 7 12:36:42 EST 2009
On Mon, 7 Dec 2009, Patrick Giraudoux wrote:
> Dear Roger,
> I have moved the thread and the answer below from qgis-user at lists.osgeo.org
> to this list as advised...
>> That is because the GRASS environment variables have not been set at that
>> point. Do you need to use GRASS in throw-away (initGRASS) mode, or with an
>> existing location? If the latter, please use the interface in the regular
>> way, starting R "within" GRASS. I'll try to reproduce the problem, but it
>> is not easy to do, I'm afraid.
Dear Patrick,
I've tried with Metis with no success. The first problem is addressed in
this draft release:
http://spatial.nhh.no/R/Devel/spgrass6_0.6-13.zip
but with Metis is simply falls over later. With WinGRASS (last but
latest), it just works. It even works in Metis once the basic GRASS
framework is set up using WinGRASS, but behaviour is erratic and
unpredictable. To track it with Metis (which I just uninstalled to try
OSGeo4W) seemed impossible, it wasn't clear where the GRASS modules were
looking for their environment variables and GISRC backstore.
I would probably use file transfer and have QGIS do the desktop mapping
and WinGRASS the analytical stuff, but I can't say that I have favourites
here.
> I would like to be capable to read into GRASS locations from within R (so not
> from R started withing GRASS) -what is supposedly done with initGRASS; eg
> just to pick up a region definition into a "spgrass6" object and compute on
> that. I though that initGRASS was design for this task.
Right, initGRASS with home=tempdir() (not what I replied earlier - with no
home= given, it uses whatever Windows says "HOME" is) starts a new
location and mapset in the R temporary directory, which you move data to
for GRASS to analyse.
>> Have you tried the WinGRASS stand-alone (I haven't trusted either QGIS
>> GRASS used this way or OSGeo4W - I follow the bug-tracker for OSGEO4W, so
>> stay away)?
> I am trying this essentially on teaching purposes. Students are working under
> Windows XP and Vista. I have only a limited number of hours, and to board GIS
> concepts from QGIS then to GRASS is somehow easier for them than straight
> within GRASS (although it is just the reverse when you know GRASS). The QGIS
> Metis standalone version was excellent for that. You have seen that the
> updates to Kore and Mimas are done with no standalone version available on
> the QGIS official site. There the use of OSGeo4W is encouraged and I am
> trying to find out what could be best advisable for the students.
> I did not tried WinGRASS yet, and I am interested in doing it, but have
> installed the OSGeo4W  GRASS 6.4svn version (works well - but definitely the
> unix/linux environment is more convenient for command lines), as well as
> OSGeo4W QGIS Kore and Mimas, and try and compare them.
Roger
>> What is your sessionInfo()?
> sessionInfo()
> R version 2.10.0 (2009-10-26)
> i386-pc-mingw32
> locale:
> [1] LC_COLLATE=French_France.1252  LC_CTYPE=French_France.1252  [3]
> LC_MONETARY=French_France.1252 LC_NUMERIC=C                 [5]
> LC_TIME=French_France.1252
> attached base packages:
> [1] grDevices datasets  splines   graphics  stats     tcltk     utils   [8]
> methods   base
> other attached packages:
> [1] spgrass6_0.6-12 XML_2.6-0       rgdal_0.6-22    sp_0.9-47     [5]
> svSocket_0.9-48 TinnR_1.0.3     R2HTML_1.59-1   Hmisc_3.7-0   [9]
> survival_2.35-7
> loaded via a namespace (and not attached):
> [1] cluster_1.12.1  grid_2.10.0     lattice_0.17-26 svMisc_0.9-56 [5]
> tools_2.10.0
>>> Have tried the following:
>>> initGRASS("C:\\OSGeo4W\\bin",home="U:\\Documents and
>>> Settings\\pgiraudo\\",override=T)
>>> initGRASS("C:\\Program Files\\Quantum GIS\\grass",home="U:\\Documents and
>>> Settings\\pgiraudo",override=T)
>>> initGRASS("C:\\OSGeo4W\\bin",override=T)
>>> with the same results...
>>> Error in system(paste("g.dirseps.exe -g",
>>> shQuote(Sys.getenv("WINGISRC"))), :
>>> g.dirseps.exe not found
>>> Error in Sys.setenv(GISRC = gisrc) : wrong length for argument
>>> Quite puzzling since g.dirseps does not give a message "unknown command"
>>> when tried within grass (thus it is suppose to be in the GRASS programme)
>> What is your sessionInfo()? Have you tried the WinGRASS stand-alone (I
>> haven't trusted either QGIS GRASS used this way or OSGeo4W - I follow the
>> bug-tracker for OSGEO4W, so stay away)?
>> Would you mind moving to the proper list - this is a GRASS question much
>> more than an R one:
>> http://lists.osgeo.org/mailman/listinfo/grass-stats
>> Roger
>>> Patrick
>>>>> Here is the result:
>>>>> library(spgrass6)
>>>>> debug(initGRASS)
>>>>>> initGRASS("C:/OSGeo4W/bin",home="U:/Documents and
>>>>> Settings/pgiraudo/",override=T)
>>>>> Browse[2]>
>>>>> debug: gisrc <- system(paste("g.dirseps.exe -g",
>>>>>   intern = TRUE)
>>>>> Browse[2]> Sys.getenv("WINGISRC")
>>>>>                                       WINGISRC
>>>>> "U:/Documents and Settings/pgiraudo/\\.grassrc6"
>>>>> Browse[2]> shQuote(Sys.getenv("WINGISRC"))
>>>>> [1] "\"U:/Documents and Settings/pgiraudo/\\.grassrc6\""
>>>>> Browse[2]> gisrc
>>>>> Error: object 'gisrc' not found
>>>> Could you try both not setting home= (you get a temporary folder that is
>>>> deleted when you exit R), or setting
>>>> home="U:\\Documents and Settings\\pgiraudo"
>>>> without the trailing forward slash?
>>>> This a problem connected to protecting spaces on the one hand and system
>>>> specific directory separators on the other, I think.
>>>> Roger
>>>>> Beforehand, the first time I run
>>>>> Settings/pgiraudo/",override=T), I got:
>>>>> Then, if I try the same commande on QGIS Metis, I got:
>>>>> initGRASS("C:/Program Files/Quantum GIS/grass",home="U:/Documents and
>>>>> Settings/pgiraudo",override=T)
>>>>> Best,
>>>>> Patrick
>>>>>> On Sun, 6 Dec 2009, Patrick Giraudoux wrote:
>>>>>>> Dear all,
>>>>>>> I am trying to init a GRASS session from within R, using the function
>>>>>>> initGRASS from the package spgrass6. GRASS is installed in two ways on
>>>>>>> my computer (here, the OS is Windows XP): with QGIS metis (precompiled
>>>>>>> version including grass 6.3 (2008)) and grass 6.4.0svn, just freshly
>>>>>>> installed with the Osgeo4W installer.
>>>>>>> In both cases I get the same result:
>>>>>>> Any idea about what happens ?
>>>>>> No, without the output of traceback(), it isn't obvious, although here
>>>>>> traceback() might not help. Run under debug(initGRASS) to the step
>>>>>> before, that is:
>>>>>>             shQuote(Sys.getenv("WINGISRC"))), intern=TRUE)
>>>>>> then run:
>>>>>> gisrc
>>>>>> and try to see what is going on. At this stage, Sys.getenv("GISRC")
>>>>>> should be "junk", assigned a couple of lines earlier.
>>>>>> Maybe the grass-stats list would have a higher proportion of users of
>>>>>> both GRASS and R.
>>>>>> Hope this helps,
>>>>>> Roger
>>>>>>> Patrick
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
