[GRASS-stats] Re: [GRASS-user] Testing i.pca ~ prcomp(), m.eigensystem ~ princomp()
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Tue Mar 31 11:07:29 EDT 2009
Agustin:
> >> Nikos, I'm probably missing a message (I do not see which is
> >> exactly the difference between the spot and the modis example),
Nikos:
> > Hi Agus. The difference is:
> > Using SPOT (range up to max. 255):
> > i.pca == prcomp(x, center=TRUE, scale=FALSE)
> > Using MODIS (range varries between bands, up to max. ~5500):
Markus M:
> Sure? Valid range: -100 - 16000 for MODIS e.g. Surface Reflectance 8-Day
> L3 Global 500m.
I am referring to the range of the specific MODIS bands that I've used,
that is:
# band 2
r.info -r mod_b2
min=0
max=5504
# band 6
r.info -r mod_b6
min=93
max=5488
# band 7
r.info -r mod_b7
min=0
max=4133
> As I would use the max possible for SPOT (255) I would also use the max
> possible for other sensors, not the observed max, otherwise statistics
> that don't do proper normalization on the fly are not comparable between
> different sensors.
> But any PCA should do normalization beforehand, not sure what R or i.pca
> are doing.
That's the question _now_ (if I am right with my tests): why isn't
normalisation (=data centering in this case) performed with the MODIS
bands I use?
> Please excuse my random comments :-)
Markus, your comments are required :-)
Cheers, Nikos
More information about the grass-stats mailing list
