[GRASS-stats] Loading a point-vector table with 466 columns
Dylan Beaudette dylan.beaudette at gmail.com
Wed May 20 21:06:50 EDT 2009
Could be a DBF-related problem.
Cheers,
Dylan
On Wed, May 20, 2009 at 6:00 PM, Nikos Alexandris
<nikos.alexandris at felis.uni-freiburg.de> wrote:
> Nikos:
>> Hi R-statisticians :-)
>> I am trying to load a BIG table (=466 columns, 875 rows) of a grass
>> point-vector map in R. It takes too long to respond (as expected of
>> course)...
>> * Is there any "limitation" in spgrass6 regarding the column numbers?
>> * Can I somehow know that the data are fed into R and I am not wasting
>> my time?
>> * Should I prefer to export as a csv the table and work in an
>> out-of-GRASS R session?
> This works perfectly. So, why loading the grass attribute table takes so
> long (if it actually works)?
> Thanks, Nikos
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-stats
More information about the grass-stats mailing list
