[GRASS-stats] Loading a point-vector table with 466 columns
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Sun May 24 07:33:36 EDT 2009
Roger wrote:
> I'm not running SQLite, nor do I have a "wide" table. Could you, Nikos,
> make a script generating a similar table in spearfish, and two small
> scripts exercising the problem (export to R with the plugin, and with the
> temporary shapefile.
I'll try my best.
Kind regards, Nikos
More information about the grass-stats mailing list
