[GRASS-stats] start R from GRASS
Roger Bivand Roger.Bivand at nhh.no
Fri May 29 05:20:01 EDT 2009
On Fri, 29 May 2009, Stefanie Obmann wrote:
> Dear users,
> Do I have to have a special order for R and GRASS folders? I got GRASS
> inside the QGIS folder, R is located on the same level as the QGIS folder.
> Is it right to start the GRASS shell and then just type 'start R'? I receive
> 'R not found' as WINDOWS alert message.
There are different understandings of PATH in MSYS (the GRASS shell) and
Windows. To start R, it is safest to give its absolute path, unless you
know definitely that Rgui.exe is on your PATH. You may see a Flash film
at:
http://spatial.nhh.no/wun09/wun_grass.swf
for an example of starting Windows Native GRASS with an absolute path.
Note that the R_LIBS environment variable may also need setting.
Hope this helps,
Roger
> Could you please tell me what's wrong?
> Thanks!
> stef
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
