[GRASS-stats] readRAST6() error (Windows XP and W2k)
    Martin Mainzer
    martmai at gmx.de
    Sat Nov 14 03:37:33 EST 2009
Roger Bivand schrieb am 08.11.2009 09:33:
> On Thu, 5 Nov 2009, Roger Bivand wrote:
>> On Thu, 5 Nov 2009, Martin Mainzer wrote:
>>> Hello at all
>>> I use R to do statistics of some GRASS data. On the windows machines
>>> (XP
>>> and W2K) there occurred a problem when using the readRAST6 command form
>>> the spgrass6 library. I think the problem is linked to the standard
>>> installation of the GRASS standalone installer (standalone version:
>>> WinGRASS-6.4.0SVN-r39626-1-Setup.exe).
>> Thanks, this is a clear report. I'll try to follow it up - it is in
>> the r.out.gdal -> readGDAL part of readRAST6, where maybe extra
>> protection is needed on the way through.
> Please try the draft package:
> http://spatial.nhh.no/R/Devel/spgrass6_0.6-12.zip
> which should protect those spaces. Source fixes commited to the
> spgrass6 module on r-spatial on sourceforge.
With the draft package, the readRAST6() works fine, also with spaces in
pathnames.
Thanks,
Martin
> However, in working on this, I found a similar problem in this Windows
> release inside v.db.addtable, in Markus Neteler's vect2neigh()
> function. The problem may have been present before - I checked because
> vect2neigh had not been converted to execGRASS() from system() because
> of space protection problems in the value of columns=. Having tried to
> fix space protection in the parsing of the interface descriptions, I
> had hoped that vect2neigh() would now work on Windows (including cases
> with spaces in the path to the vector). When there are no spaces,
> vect2neigh() now works on the Windows platform. It gets some of the
> way, but v.db.addtable fails on space parsing:
> # Using vector map name extended by layer number as table name: \
>  landuse175a_2
> #Creating table with columns (cat integer, left integer,right \
>  integer,length double precision)
> # The table <landuse175a_2> is now part of vector map <landuse175a>
> and may
> # be deleted or overwritten by GRASS modules
> # Select privileges were granted on the table
> # Reading features...
> # and: no such driver available
> # WARNING: Unable to start driver <and>
> # ERROR: Unable to open database <C:\Documents> by driver <and>
> # Current attribute table links:
> # layer <1> table <landuse175a> in database <C:\Documents and \
>  Settings\s1155\My Documents\GIS DataBase/Spearfish60/s1155/dbf/> \
>  through driver <dbf> with key <cat>
> # layer <2> table <landuse175a_2> in database <C:\Documents> through \
>  driver <and> with key <cat>
> # Vector map <landuse175a at s1155> is connected by:
> (line breaks indicated by \)
> for command:
> execGRASS("v.db.addtable", parameters=list(map=vname2a,
>         layer=as.integer(2),
>         columns="left integer,right integer,length double precision"),
>         ignore.stderr=ignore.stderr)
> This works for path strings to the vector with no spaces.
> Best wishes,
> Roger
>> Roger
>>> The standalone installer creates a folder named "GIS DataBase" under
>>> "My
>>> Documents" (note the blank in the folder name). To test where the
>>> problem is, I renamed the folder to "GISDataBase" and moved it to E:\.
>>> With this configuration everything works fine. I guess there is a
>>> problem with the blank in the folder name that is created during the
>>> installation. But this is just a guess. I hope the experts will find
>>> the
>>> problem. Here some information out of R (version 7.10.0) after
>>> calling R
>>> via "Rgui.exe" in the wxpython GUI ("cmd" in the lower part of the
>>> window "GRASS GIS Ebenen-Manager"). For the example here I used the
>>> South-Dakota data set. First with the folder name with blanks (the
>>> folder name from the standard installation):
>>>> library(spgrass6)
>>> Lade nötiges Paket: sp
>>> Lade nötiges Paket: rgdal
>>> Geospatial Data Abstraction Library extensions to R successfully loaded
>>> Loaded GDAL runtime: GDAL 1.6.2, released 2009/07/31
>>> Path to GDAL shared files: C:/Programme/R/R-2.10.0/library/rgdal/gdal
>>> Loaded PROJ.4 runtime: Rel. 4.6.1, 21 August 2008
>>> Path to PROJ.4 shared files: C:/Programme/R/R-2.10.0/library/rgdal/proj
>>> Lade nötiges Paket: XML
>>> GRASS GIS interface loaded with GRASS version: 6.4.0svn
>>> and location: South-Dakota
>>>> gmeta6()
>>> gisdbase    E:\martin\daten\GIS DataBase
>>> location    South-Dakota
>>> mapset      PERMANENT
>>> rows        466
>>> columns     633
>>> north       4928000
>>> south       4914020
>>> west        590010
>>> east        609000
>>> nsres       30
>>> ewres       30
>>> projection  +proj=utm +zone=13 +a=6378206.4 +rf=294.9786982 +no_defs
>>> +nadgrids=C:/GRASS-6-SVN/etc/nad/conus +to_meter=1.0
>>>> map <- readRAST6('geology')
>>> Tut mir leid, <DataBase/South-Dakota/PERMANENT/.tmp/geology> ist keine
>>> erlaubte Option
>>> CPL ERROR 4: `E:/martin/daten/GIS
>>> DataBase/South-Dakota/PERMANENT/.tmp/geology' does not exist in the
>>> file
>>> system,
>>> and is not recognised as a supported dataset name.
>>> Fehler in .local(.Object, ...) :
>>>  `E:/martin/daten/GIS DataBase/South-Dakota/PERMANENT/.tmp/geology'
>>> does not exist in the file system,
>>>> traceback()
>>> 8: .Call("RGDAL_OpenDataset", as.character(filename), TRUE, silent,
>>>       PACKAGE = "rgdal")
>>> 7: .local(.Object, ...)
>>> 6: initialize(value, ...)
>>> 5: initialize(value, ...)
>>> 4: new("GDALReadOnlyDataset", filename, silent = silent)
>>> 3: GDAL.open(fname, silent = silent)
>>> 2: readGDAL(rtmpfl11, p4s = getLocationProj(), silent = ignore.stderr)
>>> 1: readRAST6("geology")
>>>> sessionInfo()
>>> R version 2.10.0 (2009-10-26)
>>> i386-pc-mingw32
>>> locale:
>>> [1] LC_COLLATE=German_Germany.1252  LC_CTYPE=German_Germany.1252
>>> [3] LC_MONETARY=German_Germany.1252 LC_NUMERIC=C
>>> [5] LC_TIME=German_Germany.1252
>>> attached base packages:
>>> [1] stats     graphics  grDevices utils     datasets  methods   base
>>> other attached packages:
>>> [1] spgrass6_0.6-11 XML_2.6-0       rgdal_0.6-20    sp_0.9-44
>>> loaded via a namespace (and not attached):
>>> [1] grid_2.10.0     lattice_0.17-26
>>> And now with a folder name without blanks:
>>>> library(spgrass6)
>>>> gmeta6()
>>> gisdbase    E:\GISDataBase
>>> mapset      PERMANENT
>>> rows        466
>>> columns     633
>>> north       4928000
>>> south       4914020
>>> west        590010
>>> east        609000
>>> nsres       30
>>> ewres       30
>>> E:/GISDataBase/South-Dakota/PERMANENT/.tmp/geology has GDAL driver
>>> GTiff
>>> and has 466 rows and 633 columns
>>>> traceback()
>>> Kein traceback vefügbar
>>>> sessionInfo()
>>> i386-pc-mingw32
>>> locale:
>>> I hope this help to solve the problem.
>>> Martin
More information about the grass-stats
