[GRASS-stats] problem installing spgrass6 in R
Tim Holland timothyholland at gmail.com
Sun Oct 4 08:18:43 EDT 2009
Dear Roger,
I am sorry to keep asking for your time, but I have (what I hope is) a
fairly simple question if you have a moment.
I reinstalled everything from scratch, using all binaries from KyngChaos and
what I think was the correct order of installation.  And I still had the
same problem with spgrass6 and rgdal failing on installation.  So now I want
to try what you suggested about using the configure arguments in
install.packages.
In GRASS, I did the following
GRASS 6.4.0RC5 (mapset):~ > gdal-config --libs
-L/Library/Frameworks/GDAL.framework/Versions/1.6/unix/lib -lgdal
GRASS 6.4.0RC5 (mapset):~ > gdal-config --cflags
-I/Library/Frameworks/GDAL.framework/Versions/1.6/Headers
I then wanted to use those paths in R in install.packages.  I tried
>install.packages("spgrass6", type="source", dependencies=TRUE,
configure.args=c("-L/Library/Frameworks/GDAL.framework/Versions/1.6/unix/lib
-lgdal","-I/Library/Frameworks/GDAL.framework/Versions/1.6/Headers"))
However, I ended up with the same error messages as always regarding
spgrass6 and rgdal failing to install.  Was I doing the right thing with
'configure.args'?  Was that the right syntax / the right elements?
Thanks for the help,
Best,
Tim
Tim,
One way of handling this might be - if you will only use rgdal from
"within" GRASS, is to run the install from the rgdal source package in
that environment. Alternatively, use gdal-config within GRASS to find the
the GDAL libs (--libs) and headers (--cflags) strings to pass to the
configure arguments in install.packages() in R outside GRASS. Here rgdal
will fail after installation if the GDAL shared objects are not on the
PATH R can see.
Hope this helps,
Roger
View this message in context: http://n2.nabble.com/problem-installing-spgrass6-in-R-tp3729191p3763720.html
Sent from the Grass - Stats mailing list archive at Nabble.com.
More information about the grass-stats mailing list
