[GRASS-stats] Problem installing spdep
Roger Bivand Roger.Bivand at nhh.no
Tue Sep 29 08:55:45 EDT 2009
On Tue, 29 Sep 2009, Jarosław Jasiewicz wrote:
> Wolf Bergenheim pisze:
>> Hi,
>> I have a problem when I try to install spdep I get the following error:
>> Error: package 'Matrix' required by 'spdep' could not be found
>> Execution halted
>> ERROR: lazy loading failed for package 'spdep'
>> ** Removing '/usr/local/lib/R/site-library/spdep'
>> The downloaded packages are in
>> 	/tmp/RtmpO1y8gG/downloaded_packages
>> Warning messages:
>> 1: In install.packages("spdep", dep = T) :
>>   dependency ‘Matrix’ is not available
>> 2: In install.packages("spdep", dep = T) :
>>   installation of package 'spdep' had non-zero exit status
>> What am I doing wrong? I tried installing it with
>> install.packages("spdep", dep=T)
>> --Wolf
> It looks like dependency issue...
> use:
> install.packages("spdep",dependencies=TRUE)
> or try to install Matrix manually
Since the last R release (2.9.0 I think), Matrix has become a recommended
package. I've seen this problem in installations that had Matrix installed
in a user library before, so that after upgrading R, there are two
competing installations. If this is the case, you'd need to find out from
library(), installed.packages() and .libPaths() where the errant Matrix
is, and use remove.packages() on it, indicating the correct lib=.
Roger
PS. There are more spdep users on R-sig-geo.
> Jarek
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-stats
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
