[GRASS-stats] problem installing spgrass6 in R
Roger Bivand Roger.Bivand at nhh.no
Wed Sep 30 05:14:51 EDT 2009
On Tue, 29 Sep 2009, Tim Holland wrote:
> I was just reading the R integration section of the KyngChaos page
> (http://www.kyngchaos.com/software:grass#r_integration) and it said the
> following:
> R Integration
> GRASS can be used with R (Tiger only). You should get the latest R binaries
> (at least 2.3.0)...
> That isn't true, is it?  That it is Tiger (MacOSX 10.4) only?  Should that
> read Tiger and up?  I am on Leopard (10.5), so if it only works on Tiger
> that is a problem.  For the time being, I will assume that it can work on
> Leopard and will keep trying.
I don't think so, as I read http://www.kyngchaos.com/software:frameworks,
and higher up on the GRASS page, it should work. Installing rgdal within
the frameworks is also a possibility, especially if the GRASS install uses
the GDAL framework.
Roger
> Best,
> Tim
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
