[GRASS-stats] grass support in gstat
Massimo Di Stefano massimodisasha at gmail.com
Wed Dec 15 11:28:03 EST 2010
Hello All,
I'm tring to install gstat with grass support enabled, on a debian sid
machine (64 bit).
I've grass-6.5.svn installed in :
/usr/local/grass-6.5.svn
i used this configure line to build gstat :
./configure  --with-grass6=/usr/local/grass-6.5.svn
but the configure don't search for grass, and the make ends with this
error :
http://www.geofemengineering.it/data/gstat_grass_log
thank you for any help!
Massimo.
More information about the grass-stats mailing list
