[GRASS-stats] r.mapcalc with spgrass6
Pinaud David pinaud at cebc.cnrs.fr
Tue Jul 6 10:52:06 EDT 2010
Dear all,
I'm trying to use the GRASS function "r.mapcalc" using R package
"spgrass6", but I've got some trouble with it, I'm not even able to
parse this function:
 > library(rgdal)
Le chargement a nécessité le package : sp
Geospatial Data Abstraction Library extensions to R successfully loaded
Loaded GDAL runtime: GDAL 1.7.1, released 2010/02/08
Path to GDAL shared files: C:/PROGRA~1/R/R-211~1.1/library/rgdal/gdal
Loaded PROJ.4 runtime: Rel. 4.7.1, 23 September 2009
Path to PROJ.4 shared files: C:/PROGRA~1/R/R-211~1.1/library/rgdal/proj
 > library(spgrass6)
Le chargement a nécessité le package : XML
GRASS GIS interface loaded with GRASS version: (GRASS not running)
 > parseGRASS("r.mapcalc")
Error : syntax error, unexpected '-', expecting NAME or STRING
Parse error  does not seem to be XML, nor to identify a file name
Erreur dans parseGRASS("r.mapcalc") : r.mapcalc not parsed
I tried to change the XML encoding by
 > setXMLencoding("latin1")
without success.
For example,
 > parseGRASS("g.region")
is correctly running, I've got the description of the function.
Otherwise, my calculus with "r.mapcalc" within GRASS 6.4.0 is correctly
running.
 > sessionInfo()
R version 2.11.1 (2010-05-31)
i386-pc-mingw32
locale:
[1] LC_COLLATE=French_France.1252  LC_CTYPE=French_France.1252
LC_MONETARY=French_France.1252
[4] LC_NUMERIC=C                   LC_TIME=French_France.1252
attached base packages:
[1] stats     graphics  grDevices utils     datasets  methods   base
other attached packages:
[1] spgrass6_0.6-16 XML_3.1-0       rgdal_0.6-27    sp_0.9-65
loaded via a namespace (and not attached):
[1] grid_2.11.1    lattice_0.18-8 tools_2.11.1
 > get("SYS", envir = .GRASS_CACHE)
[1] "WinNat"
Am I missing something? Any idea?
Thank you very much for your help and patience.
David
David PINAUD
Ingénieur de Recherche "Analyses spatiales"
Centre d'Etudes Biologiques de Chizé - CNRS UPR1934
79360 Villiers-en-Bois, France
poste 485
Tel: +33 (0)5.49.09.35.58
Fax: +33 (0)5.49.09.65.26
http://www.cebc.cnrs.fr/
__________ Information from ESET Mail Security, version of virus signature database 5255 (20100706) __________
The message was checked by ESET Mail Security.
http://www.eset.com
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-stats/attachments/20100706/cf437547/pinaud.vcf
More information about the grass-stats mailing list
