[GRASS-stats] Re: [GRASS-user] problem with spgrass6
Daniel McInerney daniel.mcinerney at ucd.ie
Mon Mar 1 17:15:40 EST 2010
Hi Leo,
What is the output of r.info and r.stats -acp of
the rasters that aren't read by readRAST6?
You may need to set the NODATA argument
in readRAST6?
Daniel.
Daniel McInerney wrote:
> Hi Leo,
> these type of questions are best sent to the
> grass-stats at list.osgeo.org [1] list (cc'd here),
> which discusses GRASS-GIS, R & spgrass6 issues.
> What does sessionInfo() give?
> Best Regards,
> Daniel.
> [1] http://www.osgeo.org/mailman/listinfo/grass-stats
> Leo Hardtke wrote:
>> Hi list,
>> I am using spgrass6 in a grass6.4-R2.9.2 on Ubuntu 9.10 without problems
>> //x=readRAST6(c("raster.a","raster.b"))/
>> but when i run the same line in grass65svn it gives an error with
>> some rasters(DCELL)... (and other  are imported without
>> problems(DCELL too))
>> /CPL ERROR 4:
>> `/media/COMP/grassdb//hardtke/Bisigato/.tmp/rs7/ndvi_sum' does not
>> exist in the file system,
>> and is not recognised as a supported dataset name.
>> Error en .local(.Object, ...) :
>> /Any idea? Is it a grass65 bug? or my fault?
>> Leo Hardtke
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-stats
More information about the grass-stats mailing list
