[GRASS-stats] rgdal for R 2.7?
Roger Bivand Roger.Bivand at nhh.no
Wed Mar 10 08:15:25 EST 2010
On Thu, 11 Mar 2010, Hamish wrote:
> Hi,
> I am trying to get spgrass6 running on Debian/stable which ships with
> R 2.7.1, and clean up the GRASS/R wiki page while I'm at it:
>   http://grass.osgeo.org/wiki/R
> as the GRASS/R docs seem in need of some consolidation and updating.
> I get as far as installing the rgdal package, which complains that it is
> not available.
> The package page shows that it wants R >= 2.10.0
>   http://cran.r-project.org/web/packages/rgdal/index.html
> I'd like to try and keep the official 2.7 R package if at all possible.
> (I'm a guest on this machine)
> I see a bunch of old rgdal versions in the archive; according to the
> spgrass6 dependency listing anything newer than 0.6-7 (Feb-2009) should
> be ok.
> http://cran.r-project.org/src/contrib/Archive/rgdal/
> Is there any way to tell which is the most modern one of those that
> will still work with R 2.7.1?  (faster than download, inspect, repeat,..)
Check the dates for a version current when 2.7.1 was current and maybe get
more recent. Do the same with sp if it complains - the most recent one
needs >= 2.9.1
Hope this helps,
Roger
PS. Debian policy is very odd, R is three stable releases on from there,
maybe ask on the R-sig-deb (or similar) list.
> Is there a way to specify version with install.packages(type="source")
> or do I have to do this by hand?
> Standard GDAL 1.5.2 packages are installed on the system. (incl. the
> gdal-grass plugin)
> thanks,
> Hamish
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-stats
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
