[GRASS-stats] Correlation calculation
Rebecca Bennett rabennett at ymail.com
Thu Aug 4 05:02:22 EDT 2011
Hello all,
I am *very* new to R and am experimenting with the GRASS / R interface to look at correlation of elevation and spectral values.
Reading through the literature and mailing list, I have imported my GRASS rasters to R as a dataset looked at the summary statistics and then attempted to run a correlation analysis using cor, along the lines of the example here:
map <- readRAST6(c("lageado_10k_fisher_K_15x15",
   "lageado_10k_fisher_K_25x25"))
summary(map)
cor(as(map, "data.frame"))
and get the output:
                coombe_rev_LRM intensity_coombe          x          y
coombe_rev_LRM                1               NA         NA         NA
intensity_coombe          NA       1.00000000 -0.1525509 0.09057913
x                                NA      -0.15255095  1.0000000 0.00000000
y                                NA       0.09057913  0.0000000 1.00000000
so the correlation is running on the x and y values of the rasters not the z?
How do I begin to assess correlation in the z value of two rasters?
Many thanks for reading, (and sorry if my question seems stupid or I have missed something obvious)
Rebecca
URL: http://lists.osgeo.org/pipermail/grass-stats/attachments/20110804/4d14f0b0/attachment.html
More information about the grass-stats mailing list
