[GRASS-stats] Changes to execGRASS()
Roger Bivand Roger.Bivand at nhh.no
Sat Aug 20 13:25:53 EDT 2011
Following Rainer's talk at useR! 2011, I have made a number of changes to
execGRASS() and other functions in spgrass6 - the code is committed to
R-Forge project rspatial module spgrass6, and should be built this evening
as a source package, with version 0.7-4 and revision 1121.
The changes are 1) to introduce central options for ignore.stderr and
useGDAL; 2) to parse interface description parameters for defaults, and to
supply these defaults for omitted parameters; 3) to permit parameters to
be passed as ... in execGRASS() and doGRASS() instead of parameters=list()
- either representation may be used, but not both.
This means that ... in execGRASS() is now used for GRASS parameters, so
all of the arguments to system() - which previously received the ...
arguments - have to be named and given explicitly, otherwise they will be
passed to GRASS. In particular, the "input" argument to system() collides
with input= parameters to GRASS - see ?execGRASS for system() argument
names.
The committed code checks in spearfish for R 2.13.1 and R-devel with both
the current release branch 6.4.2svn47586 and development trunk
7.0svn47783. It would be very useful if others could try this spgrass6
code to see how far existing scripts are affected.
The 0.7 series began with the introduction of a NAMESPACE, a requirement
for the next release of R in October.
Thanks to Rainer for interesting suggestions!
Roger
Roger Bivand
Department of Economics, NHH Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
