[GRASS-stats] Re: grass-stats Digest, Vol 49, Issue 1
Duccio Rocchini ducciorocchini at gmail.com
Thu Jan 6 15:09:49 EST 2011
Dear Nikos
many compliments for this elegant solution.
At a first glance, I would suggest using ANOSIM which is implemented
into vegan too but it seems that MRPP worked in a great way and that
you have seen the sunny part of the road in few time!
Duccio
Duccio Rocchini, PhD
Edmund Mach Foundation
IASMA Research and Innovation Centre
Department of Biodiversity and Molecular Ecology
GIS and Remote Sensing Unit
Via Mach 1, 38010 San Michele all'Adige (TN) - Italy
Phone +39 0461 615 570
duccio.rocchini at iasma.it
skype: duccio.rocchini
web page: http://gis.fem-environment.eu/rocchini/
2011/1/6  <grass-stats-request at lists.osgeo.org>:
> Send grass-stats mailing list submissions to
>        grass-stats at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>        http://lists.osgeo.org/mailman/listinfo/grass-stats
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>        grass-stats-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of grass-stats digest..."
> Today's Topics:
>   1. Re: Spatial autocorrelation of multi-spectral,    uni- and
>      mutli-temporal data sets (Nikos Alexandris)
> Message: 1
> Date: Thu, 6 Jan 2011 16:56:36 +0200
> From: Nikos Alexandris <nik at nikosalexandris.net>
> Subject: Re: [GRASS-stats] Spatial autocorrelation of multi-spectral,
>        uni- and mutli-temporal data sets
> To: grass-stats at lists.osgeo.org
> Message-ID: <201101061656.38683.nik at nikosalexandris.net>
> Content-Type: Text/Plain;  charset="utf-8"
> On Sunday 26 of December 2010 19:00:32 Nikos Alexandris wrote:
>> Greets to the statists,
>> I want to "describe" my multispectral (Landsat5_TM) composite datasets with
>> respect to their between vs. within heterogeneity.
> (Replying to myself and for the potential interest of anybody reading the
> list... )
> Finally I went for MRPP test(s) implemented in the R-package "vegan"[1][2]. I
> did a sampling of major land cover classes after all (such as Urban areas,
> vegetation, bare ground, water bodies, etc)., put the data in data.frames and
> ran the tests.
> The data.frames look like:
> str ( samples_postfire_modis )
> 'data.frame':   1040 obs. of  6 variables:
>  $ Band 1: int  1354 1458 1458 1458 1550 1145 1428 1573 1573 1657 ...
>  $ Band 2: int  3088 2971 2971 2971 2902 2990 2942 2824 2824 2917 ...
>  $ Band 5: int  3533 3506 3506 3506 3323 3535 3337 3239 3239 3552 ...
>  $ Band 6: int  2778 2803 2803 2803 2974 2646 2674 2883 2883 3071 ...
>  $ Band 7: int  2019 2146 2146 2146 2042 1719 2045 2114 2114 2373 ...
>  $ Class : Factor w/ 5 levels "Urban","Vegetation",..: 1 1 1 1 1 1 1 1 1 1 ...
>> str ( samples_bite )
> samples_bitemporal_modis.colnames  samples_bitemporal_modis
>> str ( samples_bitemporal_modis )
> 'data.frame':   1040 obs. of  7 variables:
>  $ Prefire B2 : int  3377 3425 3304 3179 3247 3247 3235 3043 3043 3197 ...
>  $ Prefire B6 : int  2726 2683 2737 2991 2934 2934 2928 2984 2984 3199 ...
>  $ Prefire B7 : int  1864 1932 2005 2185 2068 2068 2223 2331 2331 2314 ...
>  $ Postfire B2: int  3088 2971 2971 2971 2902 2990 2942 2824 2824 2917 ...
>  $ Postfire B6: int  2778 2803 2803 2803 2974 2646 2674 2883 2883 3071 ...
>  $ Postfire B7: int  2019 2146 2146 2146 2042 1719 2045 2114 2114 2373 ...
> 1 ...
> Some of the results look like this:
> Call:
> mrpp(dat = samples_postfire_modis.smallsample.300[, 1:5], grouping =
> samples_postfire_modis.smallsample.300[["Class"]])
> Dissimilarity index: euclidean
> Weights for groups:  n
> Class means and counts:
>      Urban Vegetation Bare ground Burned Water
> delta  1241  1029       1550        1228  855.2
> n     97    81         63          53     6
> Chance corrected within-group agreement A: 0.3956
> Based on observed delta 1239 and expected delta 2050
> Significance of delta: 0.001
> Based on  999  permutations
> and
> + samples_postfire_modis.smallsample.300.vegdist <- vegdist (
> samples_postfire_modis.smallsample.300[,1:5] )
> + samples_postfire_modis.smallsample.300.md <- meandist (
> samples_postfire_modis.smallsample.300.vegdist ,
> samples_postfire_modis.smallsample.300[["Class"]] )
> + summary(samples_postfire_modis.smallsample.300.md)
> Mean distances:
>                 Average
> within groups  0.0950253
> between groups 0.2023877
> overall        0.1754765
> Summary statistics:
>                        Statistic
> MRPP A weights n        0.4224480
> MRPP A weights n-1      0.4263591
> MRPP A weights n(n-1)   0.4584728
> Classification strength 0.1010409
> Running the above test on samples with observations > 3000 is a high load for
> a home-machine (working here on Core2 Duo @2.53GHz and 6GB RAM). In fact,
> running the process for 18K observations times 6 variables (the number of
> permutations increases like crazy...) took 2+1/2 days (double that for another
> data.frame of the same size).
> Wish I had access to some OSGeo super-computer for 30 mins to get this job
> done.
> Greets, Nikos
> End of grass-stats Digest, Vol 49, Issue 1
More information about the grass-stats mailing list
