[GRASS-stats] Error using GRASS from R
Tim Besser bessertim at gmx.de
Thu Jul 21 04:28:22 EDT 2011
Ok, now I tried it in the GRASS terminal. Used parseGRASS("r.reclass")
and it showed me the GRASS output as desired. With parseGRASS("r.patch")
I had the same error as before: "r.patch not found"
I am a programming beginner and I am very happy that I managed writing a
R script which does everything I need step by step. I begin to
understand that doing this from R to GRASS is not too straight-forward.
But I got quiet familiar in R coding.
When I start R from GRASS (I managed) how do I use the GRASS-commands
then. No initGRASS and no execGRASS, but what else?
And the last thing. The file extensions in Win you meant? Enabled them
but still the same error.
Cheers,
Tim
Am 20.07.2011 20:32, schrieb Roger Bivand:
> On Wed, 20 Jul 2011, Tim Besser wrote:
>> Dear GRASS-community,
>> I have a very strange problem. I wrote a script in R (2.10.1) for the
>> preparation of my datasets which works fine on my laptop (winxp). I
>> do not start my R session from GRASS but use GRASS through the
>> initGRASS and execGRASS commands. I use the "spgrass6" package and
>> GRASS 6.4.1. As the script would run for days on my old laptop I now
>> got a remote desktop connection to a much faster computer at the
>> university (win7). However, while cmds like r.reclass or r.in.gdal
>> (execGRASS) work on that computer the r.patch (execGRASS) cmd
>> produces following error:
> Do not start R in GRASS using initGRASS when you are using an exiting
> location - I will most likely remove this possibility at the next
> release as it confuses users. Start in the usual way by starting GRASS
> in a terminal - text interface - and then start R from the GRASS
> prompt, or use the MSYS console within GRASS (the second of the two
> GRASS icons).
> In your case, I cannot even see why you need R - why not just write a
> shell script, or in GRASS 7 a Python script?
> Can you run parseGRASS("r.patch")? What does parseGRASS("r.reclass")
> return? For some reason, your remote Windows GRASS installation
> appears to be treating programs differently. Make sure that you expose
> the extensions when you observe the names of files under Windows - by
> default it displays names without extensions, and a missing extension
> may be the problem. There may also be an issue in the way that Win7
> handles DOS-style path formats - I have no access to such an OS, so
> have no idea. I cannot see any differences with the Windows native
> GRASS 6.4.1 on XP.
> Createprocess is what starts a new process, and may possibly have
> permissions issues. You'd need to run the same thing locally on an
> identical Win7 system with the same permissions to check. Using a
> shell script would avoid this, I believe.
> Roger
>> execGRASS("r.patch", flags=c("z"),
>> parameters=list(input="mangroves_1989_138_044_LR_recl,mangroves_1989_138_045_UL_recl,mangroves_1989_138_045_UR_recl",
>> output="testomat"), intern=T)
>> Error in system(cmd0, intern = TRUE) :
>>  Createprocess konnte 'C:\GRASS6~1.1\bin\RPATCH~1.EXE
>> --interface-description' nicht ausführen
>> Fehler in parseGRASS(cmd) : r.patch not found
>> I checked the GRASS directory and it is set right in the initGRASS
>> command.
>> I hope you can help me with one. I have no clue what to do!
>> Thanks in advance,
>> Tim
>> grass-stats mailing list
>> grass-stats at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-stats
More information about the grass-stats mailing list
