[GRASS-stats] Little r
Hamish hamish_b at yahoo.com
Fri Oct 28 00:58:11 EDT 2011
Hi there,
I just came across this, perhaps it makes some task easier for
someone:
$ apt-cache show littler
Description: GNU R scripting and command-line front-end
The 'r' (aka 'littler') program provides a leightweight binary wrapper around
the GNU R language and environment for statistical computing and graphics.
While R can be used in batch mode, the r binary adds full support for
both 'shebang'-style scripting (i.e. using a  hashmark-exclamation-path
expression as the first line in scripts) as well as command-line use in
standard Unix pipelines. In other words, r provides the R language without
the environment.
Hamish
More information about the grass-stats mailing list
