[GRASS-stats] GRASS within R interface issues
Roger Bivand Roger.Bivand at nhh.no
Fri May 4 16:13:24 EDT 2012
On Fri, 4 May 2012, Laura S wrote:
> Dear Roger:
> What I have been seeking to do from the very beginning is to run R
> within GRASS directly on XP. In other words, type "R" in the GRASS
> console and have R run. This does not workfor me yet. I have looked in
> books/websites. From what I have read, they indicate that you run R
> within GRASS, but not the actual set up to make R recognizable to GRASS
> when it spits out " 'R' is not recognized as an internal or external
> command, operable program or batch file"; the output that has started
> this whole process of me trying to figure out the disconnect. Here is an
> example of what I want to do, and how when I try to do the same
> operation it fails:
If you mean the GRASS "Command console" tab in the GUI Layer Manager, it
cannot be used to run interactive R. It can perhaps be used to run a
single R script and exit. This is definitely not supported, and is
illogical, as that tab is only for running modules that run and exit,
writing to the standard output window above. I can start R in the Command
console tab under Linux, but not under Windows XP.
By the way, using the full path to Rgui.exe from the MSYS prompt with &
also works in Windows 7.
If you want to run R in GRASS on Windows, use Rgui.exe as I have
explained, or possibly R.exe at the MSYS prompt. You have not shown why
your proposed action has any sense or merit, and I think that asking
people for their experienced doing something for which nothing was
designed, and which cannot work, does show that you need to understand how
computers and programs work. You could read the code of the Layer Manager
Command console tab to see whether it could be improved to permit
interactive programs to be run, but continuing this thread seems
pointless. Asking unidentified users for their experiences when the person
who wrote the R/GRASS interface has explained how to use it, is
irritating, I'm afraid.
When the console reports that the command cannot be found, it is because
it is not on the current search path, often the PATH environment variable,
which is why one often uses an absolute address. On Windows XP, I cannot
get any R executable to start from the Layer Manager Command console tab.
The "Command console" tab is not for running R interactively, period.
Roger
> ######### Startup
> 	* Start GRASS. At the GRASS command line start R.
> In this example we will use the sample Spearfish dataset.
> Reset the region settings to the defaults
> GRASS> g.region -d
> Launch R from the GRASS prompt
> GRASS> R
> Load the spgrass6 library:
>> library(spgrass6)
> Get the GRASS environment (mapset, region, map projection, etc.); you can display the metadata for your location by printing G:
>> G <- gmeta6()
> ########### This is what I get from the GRASS command line, which mirrors the MSYS, etc. problem I am having:
> GRASS 6.4.2RC2> g.region -d
> GRASS 6.4.2RC2> R
> 'R' is not recognized as an internal or external command, operable program or batch file
> ########## Others are having the same problem, and I have had people email me privately to let them know what I uncover.
> Cheers,
> Laura
> ________________________________
> From: Roger Bivand <Roger.Bivand at nhh.no>
> To: Laura S <les_ecol at yahoo.com>
> Cc: "grass-stats at lists.osgeo.org" <grass-stats at lists.osgeo.org>
> Sent: Friday, May 4, 2012 12:12:29 AM
> Subject: Re: [GRASS-stats] GRASS within R interface issues
>> Dear Roger:
>> Thank you. I am still puzzling a bit. Now the following happens: (i) R pops up, (ii) GRASS is not frozen, (ii) but there is no recognition of R in GRASS GUI with MSYS. How do I get R to be recognized directly within GRASS? I keep getting "sh: R: command not found" in the GRASS GUI with MSYS.
>> Here are my newest steps thus far:
>> 1. In GRASS GUI with MSYS:
>> GRASS 6.4 > "C:/Programs.../Rgui.exe" &
>> [1] 3532
>> 2. Pops up R window without freezing console, but still does not recognize R, as shown in # 3.
>> 3. GRASS 6.4 > R
>> sh: R : command not found
> Well, you have a running R session, do you want a second one? If you prefer not to use the R GUI, you may use R.exe in step 2 but without the &, as then the R CLI will run in the MSYS console. I do not understand why you do step 3 - you asked before about issuing GRASS commands at the MSYS prompt? Can you get local help from someone who can look over your shoulder?
> Roger
>> Thank you,
>> Laura
>> To: Laura S <les_ecol at yahoo.com> Cc: "grass-stats at lists.osgeo.org" <grass-stats at lists.osgeo.org> Sent: Wednesday, May 2, 2012 11:44:57 AM
>> On Sat, 28 Apr 2012, Laura S wrote:
>>> Dear all:
>>> I emailed around and others have the same issue of the freezing GRASS console and not being able to run R within GRASS, and many resort to doing GRASS commands within R using execGRASS().
>> You do need to understand what you are doing, I'm afraid.
>> If you just enter "C:\Program Files\ ... \Rgui.exe" at the MSYS prompt, it starts R and does not return until you exit R. If, however, you trat MSYS as Unix, and add & after the "C:\Program Files\ ... \Rgui.exe" (only tried on XP as this is the Windows version involved here):
>> "C:\Program Files\ ... \Rgui.exe" &
>> MSYS will start R within GRASS, and return to its prompt - which I think is what you want. In addition, you can run GRASS commands from the GRASS GUI, either using the point and click GUI, or typing into the command console tab at the bottom of the layer manager, in addition to the equivalent execGRASS() in R.
>> Hope this clarifies,
>> Roger
>>> I am going to keep searching around for a fix, as I still cannot run R within GRASS on XP. I am trying to figure this out for myself and other collaborators.
>>> Cheers,
>>> Laura
>>> From: Laura S <les_ecol at yahoo.com>
>>> To: "grass-stats at lists.osgeo.org" <grass-stats at lists.osgeo.org> Sent: Monday, April 23, 2012 2:34:40 PM
>>> Subject: [GRASS-stats] GRASS with R interface issues - running R within GRASS 6.4.2
>>> Dear all:
>>> Do you have any suggestions on this? Thank you.
>>> I cannot type in the GRASS GUI with MSYS window and execute commands. It is frozen, and when I open up another GRASS console and type R the console says: "R is not recognizable as an internal or external command, operable program or batch file."
>>> I provide examples below. Roger has been helpful, but I am still unsure if I am missing something, or there is a bug.
>>> I have found bugs in other programs, e.g., WinRhizo, but I am assuming GRASS is working fine. I have been looking for screenshot instructions to better understand my issue, so anyone knows of these posted somewhere, this would be helpful.
>>> Laura
>>> On Mon, 23 Apr 2012, Laura S wrote:
>>>> Dear Roger and others:
>>>> My apologies if I am not piecing everything together. I think I am almost there; I appreciate your patience.
>>>> This is my current point of confusion, and what I am able to do so far:
>>> I. My main point of confusion is that when I type the path into GRASS MSYS, the R console window pops up, and I am unable to type more into the GRASS console. I cannot type GRASS commands in R, so I am unsure where I type the GRASS commands if GRASS console does not let me type more, and the R console does not recognize R commands.
>>> Why should
>>> it? Simply minimise the R GUI to work in GRASS directly, using the GRASS GUI or from the prompt in MSYS. I doubt very much whether saying d.ask makes sense anyway, as the GRASS display GUI covers that.
>>> It
>>> is possible to write GRASS commands using execGRASS() from the R console, but since you have had to ask, you will find it easier simply to minimise R and use GRASS directly. Because R is within GRASS, it "sees" the current status of the location.
>>> Hope this clarifies - please change to one of the GRASS lists for further help.
>>> Roger
>>>> II. What I can do so far in more detail:
>>> 1. Within the GRASS 6.4.2RC2 with MSYS, I typed using tab autocompletion: "C:/Program Files/R/R-2.14/bin/i386/Rgui.exe" which causes the RGui to pop up as a second R window. Thus, I am not in GRASS directly anymore I assume, but rather in the RGui. In this GUI, it says the following when I type library(spgrass6): "GRASS GIS Interface loaded
>>> with GRASS version GRASS 6.4.2RC2exported (2011) and location: demolocation" gmeta6() gisdbase C:/Documents etc.
>>>> If I try a GRASS command such as "d.ask" in the RGUI after loading spgrass:
>>>> d.ask
>>>> Error: object 'd.ask' not found
>>> 2. I can also get this to work in R directly: loc <- initGRASS("C:/Program Files/Grass 6.4",home=tempdir()) gmeta6() **prints
>>> gisdbase, etc.**
>>>> d.ask
>>>> Thank you for your help,
>>>> Laura
>>> grass-stats mailing list
>>> http://lists.osgeo.org/mailman/listinfo/grass-stats
>> -- Roger Bivand
>> Department of Economics, NHH Norwegian School of Economics,
>> Helleveien 30, N-5045 Bergen, Norway.
>> voice: +47 55 95 93 55; fax +47 55 95 95 43
>> e-mail: Roger.Bivand at nhh.no
> -- Roger Bivand
Roger Bivand
More information about the grass-stats mailing list
