[GRASS-stats] How to give projection to polygons and calculate area
Nicolás Mari nicolasalejandromari at gmail.com
Wed May 22 11:58:34 PDT 2013
Dear Markus and Hamish,
Thanks a lot.
I am working with vectors.
How can i give the parameters of the new location via g.proj -c? for
example for a laea projection? (All inside R via execGRASS)
when i have the new location a use v,proj.
And then i use v.db.addcol to add a column called area.
then i use v.to.db to calculate it.
Do you think that is allright?
Thanks for your help.
Nicolas
2013/5/22 Markus Metz <markus.metz.giswork at gmail.com>
> On Tue, May 21, 2013 at 11:54 PM, Hamish <hamish_b at yahoo.com> wrote:
> > Nicolás wrote:
> >> I am working with GRASS functions in R batch job:
> >> I need to calculate areas from polygons which are in a
> >> geographical projection. To do so, i would like to define a new
> >> projection (Lamert Azimutal Equal Area) to my polygons, and the
> >> to calculate areas.
> > raster areas or vector areas?
> > (GRASS's r.* modules generally deal with that and give the
> > correct area in sq-meters automatically, so no need to reproject;
> > the v.* modules generally/often do not [yet])
> A simple query by clicking on the polygon will give square meters for
> latlon. v.to.db uploads values in meters or square meters for latlon,
> or miles, feet, acres, hectares when requested.
> Markus M
> > if you'd like to make a new location in GRASS via a script,
> > you can use the g.proj module to do that (-c flag), then use
> > a GRASS_BATCH_JOB to automatically pull the vector map in with
> > v.proj and do the calculation.
> > Hamish
> > grass-stats mailing list
> > grass-stats at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-stats
Nicolás
*P** *Think before print
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20130522/550238ba/attachment.html>
More information about the grass-stats mailing list
