[GRASS-stats] Cryptic warning when reading raster which consists only of NULL
Rainer M Krug Rainer at krugs.de
Wed Sep 18 00:43:43 PDT 2013
Roger Bivand <Roger.Bivand at nhh.no> writes:
> Rainer,
> Please provide R code to generate such a raster using execGRASS() -
I tried it under 6.4 and 7 and the error occurs under both, but only
have the R code for 7 as it uses r.mapcalc:
| > library(spgrass6)
| > execGRASS("r.mapcalc", expression="round(null())")
| > execGRASS("r.info", map="NULL")
|  | Layer:    NULL                           Date: Wed Sep 18 09:36:57 2013    |
|  | Mapset:   asmDrak                        Login of Creator: rainerkrug      |
|  | Location: grass                                                            |
|  | DataBase: /Users/rainerkrug/Documents/Projects/AlienManagementDrakensberg/ |
|  | Title:     ( NULL )                                                        |
|  | Timestamp: none                                                            |
|  |   Type of Map:  raster               Number of Categories: 0               |
|  |   Data Type:    CELL                                                       |
|  |   Rows:         330                                                        |
|  |   Columns:      300                                                        |
|  |   Total Cells:  99000                                                      |
|  |        Projection: Albers Equal Area                                       |
|  |            N:     -70000    S:    -103000   Res:   100                     |
|  |            E:    -130000    W:    -160000   Res:   100                     |
|  |   Range of data:    min = NULL  max = NULL                                 |
|  |   Data Description:                                                        |
|  |    generated by r.mapcalc                                                  |
|  |   Comments:        |
|  |    round(null())                                                           |
| > x <- readRAST6("NULL", useGDAL=FALSE, plugin=FALSE)
| Creating BIL support files...
| Exporting raster as integer values (bytes=4)
|  100%
| Warning messages:
| 1: In lapply(lres, as.numeric) : NAs introduced by coercion
| 2: In lapply(lres, as.numeric) : NAs introduced by coercion
| > x <- readRAST6("NULL", useGDAL=TRUE, plugin=FALSE)
| Loading required package: rgdal
| rgdal: version: 0.8-11, (SVN revision 479M)
| Geospatial Data Abstraction Library extensions to R successfully loaded
| Loaded GDAL runtime: GDAL 1.10.0, released 2013/04/24
| Path to GDAL shared files: /usr/local/Cellar/gdal/1.10.0/share/gdal
| Loaded PROJ.4 runtime: Rel. 4.8.0, 6 March 2012, [PJ_VERSION: 480]
| Path to PROJ.4 shared files: (autodetected)
| Warning message:
| statistics not supported by this driver
It also only occurs when GDAL is not used.
It seems that the problem is the GRASS null() in CELL maps.
> I'm not sure that I can resolve this by guessing. Please also don't
> assume that posting via a newsgroup stays in thread - I'll try to
> reply using that route; the statgrass list is more appropriate anyway.
Sorry - I reposted it on statgrass.
Hope this helps,
Rainer
> Roger
> PS: [News not posted: "/usr/bin/inews -h": Error running
> "/usr/bin/inews -h"] - newsgroup not a feasible reply route - please
> revert to posting via mailing list (in gmane if you prefer).
> On Tue, 17 Sep 2013, Rainer M Krug wrote:
>> Hi
>> When reading a raster from GRASS which consists only of NULL, a cryptic
>> warning is received:
>> | Warning in lapply(lres, as.numeric) : NAs introduced by coercion
>> This is caused by the line
>> | lres <- lapply(lres, as.numeric)
>> in the debug session below:
>> | debug: con <- textConnection(tx)
>> | Browse[2]>
>> | debug: res <- read.dcf(con)
>> | Browse[2]>
>> | debug: close(con)
>> | Browse[2]>
>> | debug: lres <- as.list(res)
>> | Browse[2]>
>> | debug: names(lres) <- colnames(res)
>> | Browse[2]>
>> | debug: lres <- lapply(lres, as.numeric)
>> | Browse[2]>
>> | debug: if (!is.numeric(lres$min) || !is.finite(as.double(lres$min))) NODATA <- as.integer(999) else {
>> |     lres$min <- floor(as.double(lres$min))
>> |     NODATA <- floor(lres$min) - 1
>> | Browse[2]> lres
>> | $min
>> | [1] NA
>> | $max
>> | [1] NA
>> | Browse[2]> tx
>> | [1] "min:NULL" "max:NULL"
>> | Browse[2]>
>> I would suggest to add thwe statements
>> | if (lres[[1]]=="NULL") lrews[[1]] <- NA
>> | if (lres[[2]]=="NULL") lrews[[2]] <- NA
>> before the line
>> as this would replace the "NULL" with NA and not cause the error.
>> | > sessionInfo()
>> | R version 3.0.1 (2013-05-16)
>> | Platform: x86_64-apple-darwin10.8.0 (64-bit)
>> | locale:
>> | [1] C
>> | attached base packages:
>> | [1] stats     graphics  grDevices utils     datasets  methods   base
>> | other attached packages:
>> |  [1] asmDrak_0.0-1        maptools_0.8-27      simecol_0.8-2
>> |  [4] lattice_0.20-23      deSolve_1.10-7       prioritization_0.0-1
>> |  [7] seedGerm_0.0-1       seedDisp_0.4-13      Rcpp_0.10.4
>> | [10] seedProd_0.0-1       fireSim_0.0-1        RSQLite_0.11.4
>> | [13] DBI_0.2-7            spgrass6_0.8-3       XML_3.95-0.2
>> | [16] sp_1.0-13            logger_0.0-1         devtools_1.3.99
>> | loaded via a namespace (and not attached):
>> |  [1] RCurl_1.95-4.1 compiler_3.0.1 digest_0.6.3   evaluate_0.4.7 foreign_0.8-53
>> |  [6] grid_3.0.1     httr_0.2       memoise_0.1    parallel_3.0.1 stringr_0.6.2
>> | [11] tools_3.0.1    whisker_0.3-2
>> | > version
>> |                _
>> | platform       x86_64-apple-darwin10.8.0
>> | arch           x86_64
>> | os             darwin10.8.0
>> | system         x86_64, darwin10.8.0
>> | status
>> | major          3
>> | minor          0.1
>> | year           2013
>> | month          05
>> | day            16
>> | svn rev        62743
>> | language       R
>> | version.string R version 3.0.1 (2013-05-16)
>> | nickname       Good Sport
>> Thanks,
>> Rainer
<#secure method=pgpmime mode=sign>
Roger
> Hi
> | Browse[2]>
> | Browse[2]>
> | debug: close(con)
> | Browse[2]>
> | Browse[2]>
> | Browse[2]>
> | Browse[2]>
> | debug:
Rainer at krugs dot de
More information about the grass-stats mailing list
