[GRASS-stats] spgrass7 support for strds?
Edzer Pebesma edzer.pebesma at uni-muenster.de
Thu Feb 12 06:04:02 PST 2015
I'm in favour of rgrass.
On 02/12/2015 12:13 PM, Ahmadou Dicko wrote:
> I will also cast my vote in favor of 'rgrass' because of the consistency
> with other library and gis linked to R (RSAGA, rgeos, rgdal, etc.).
> We can just then make sure that it works with both version of GRASS (6
> and 7).
> I also started a project (idea) a long time ago with Rainer to have
> something similar to pygrass[1] in R through Rcpp
> (https://github.com/RGRASS/grassRLink) in order to access the low level
> GRASS API.
> I didn't have time to finish it but I will have more time this summer
> and hope to work on it again.
> I think it can be a good idea of GSOC for either GRASS or R.
> [1]: http://grasswiki.osgeo.org/wiki/Python/pygrass
> On Thu, Feb 12, 2015 at 10:51 AM, Rainer M Krug <Rainer at krugs.de
> <mailto:Rainer at krugs.de>> wrote:
>     Roger Bivand <Roger.Bivand at nhh.no <mailto:Roger.Bivand at nhh.no>> writes:
>     > Question further down ...
>     > On Wed, 11 Feb 2015, Edzer Pebesma wrote:
>     >> On 02/11/2015 03:42 PM, Rainer M Krug wrote:
>     >>> Edzer Pebesma <edzer.pebesma at uni-muenster.de
>     <mailto:edzer.pebesma at uni-muenster.de>> writes:
>     >>>>>> Since I'm uncertain whether the maintainer of spacetime is on
>     this
>     >>>>>> list, I'm CC-ing him here. It might make sense to discuss this -
>     >>>>>> perhaps spgrass7 in the R-forge spgrass project is a logical
>     place to
>     >>>>>> support these functions?
>     >>>>> It is a brilliant idea to support spatio-temporal data in the
>     spgrass7
>     >>>>> framework.
>     >>>>> I agree that the functions should be in spgrass7 and that they
>     should
>     >>>>> have the same interface structure as the other
>     read/write[RAST/VECT]
>     >>>>> functions.
>     >>>>> I never used the package spacetime or spatio-temporal datasets
>     in GRASS,
>     >>>>> but maybe these functions could be re-used (or at least parts
>     of it)?
>     >>>> yes; and use the TGRASS (Cc: Soeren, the author), framework. Also,
>     >>>> raster stacks with time z should be of interest (Cc: Robert).
>     >>> Please forgive my ignorance - but is there actually an accepted (as
>     >>> SpatialGridDataFrame et al are accepted) object framework for these
>     >>> spatio-temporal datasets in R? It sounds as if there is not at
>     the moment?
>     >> When is something accepted? raster and spacetime have both been
>     on CRAN
>     >> for some years, and have both been considered useful by people
>     >> independent from the developers. There is a SpatioTemporal task view
>     >> that tries to list everything possibly relevant.
>     >>>>> But this should not hold back the release of spgrass7 in it's
>     current
>     >>>>> form.
>     >>>> I suggest to rename this package to "grass", supporting the current
>     >>>> grass release.
>     >>>> Grass took 7 years to move 6 to 7; I discussed this with Markus
>     last
>     >>>> night, they might as well give up this crazy major version
>     release cycle
>     >>>> idea, with all kind of restrictions they impose on themselves.
>     >>> This might cause confusion. And as long as GRASS has major
>     versions, I
>     >>> think we should stick with this naming scheme.
>     >> We don't do this with rgdal, rgeos, RSAGA, RArcInfo, and so on.
>     But many
>     >> of these have an "r" in front. This seems obsolete as they are R
>     >> packages, but may be helpful in sentences like "We used grass and the
>     >> r-package rgrass for carrying out multidimensional scaling on the
>     MODIS
>     >> imagery ...", which, without the leading r, would have the word
>     "grass"
>     >> twice in it referring to different things.
>     >> spgrass has sp in it for historic reasons - we thought about
>     prefixing
>     >> everything with sp in the early sp days. Now sp is default, and one
>     >> could think about a better name.
>     > OK, I think we keep (archived) "GRASS" for the interface to GRASS 5,
>     > "spgrass6" for GRASS 6. As of now, we've called the development
>     > version "spgrass7", but arguably "rgrass" could be preferred. As GRASS
>     > 7 is due on Sunday, could I ask for a quick show of hands on
>     > "spgrass7" or "rgrass" as the name for the package to be submitted to
>     > CRAN (tomorrow)? We can continue to consider moving spacetime code to
>     > this package, but we should have the new package on CRAN matching the
>     > release of GRASS 7.
>     The r in front makes sense - but if one looks at the changes in the
>     interface between GRASS 6 and GRASS 7 I would keep the 7 - so I would
>     suggest
>     rgrass7
>     and possibly also release the (modified) spgrass6 as rgrass6, and leave
>     spgrass6 there for compatibility, and give a warning upon load that the
>     package has been superseded by rgrass6.
>     This also opens the possibility of releasing a package called
>     rgrass
>     which then, depending on the GRASS version loaded / requested loads the
>     corresponding rgrassX package.
>     Rainer
>     > Roger
>     >>> Cheers,
>     >>> Rainer
>     >>>>> Cheers,
>     >>>>> Rainer
>     >>>>>> Roger
>     >>>>>> On Wed, 11 Feb 2015, Veronica Andreo wrote:
>     >>>>>>> Hi
>     >>>>>>> Since you are discussing the new spgrass for GRASS 7 (and since GRASS 7
>     >>>>>>> includes these great temporal modules), I was wondering if there's any
>     >>>>>>> chance to include support for reading/writing spatio-temporal data sets.
>     >>>>>>> At present, there are two functions in spacetime package (read.tgrass and
>     >>>>>>> write.tgrass) that allows reading and writing strds, but you need to export
>     >>>>>>> it from GRASS first, do the R processing you need, and then, import it back
>     >>>>>>> into GRASS. To have something a bit more straightforward would be awesome!
>     >>>>>>> I don't know how complicated this could be, that's why I dare to ask :)
>     >>>>>>> Keep the great job you are doing!!! And thanks a lot!!!
>     >>>>>>> Cheers,
>     >>>>>>> Vero
>     >>>>> _______________________________________________
>     >>>>> grass-stats mailing list
>     >>>>> grass-stats at lists.osgeo.org <mailto:grass-stats at lists.osgeo.org>
>     >>>>> http://lists.osgeo.org/mailman/listinfo/grass-stats
>     Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
>     Biology, UCT), Dipl. Phys. (Germany)
>     Centre of Excellence for Invasion Biology
>     Stellenbosch University
>     South Africa
>     Tel :       +33 - (0)9 53 10 27 44
>     <tel:%2B33%20-%20%280%299%2053%2010%2027%2044>
>     Cell:       +33 - (0)6 85 62 59 98
>     <tel:%2B33%20-%20%280%296%2085%2062%2059%2098>
>     Fax :       +33 - (0)9 58 10 27 44
>     <tel:%2B33%20-%20%280%299%2058%2010%2027%2044>
>     Fax (D):    +49 - (0)3 21 21 25 22 44
>     <tel:%2B49%20-%20%280%293%2021%2021%2025%2022%2044>
>     email:      Rainer at krugs.de <mailto:Rainer at krugs.de>
>     Skype:      RMkrug
>     PGP: 0x0F52F982
> Ahmadou H. DICKO
> statistician economist (Ingénieur Statisticien Économiste)
> PhD candidate in Climate change economics
> Faculty of economics and managment - Cheikh Anta Diop University
> West African Science Service Center on Climate Change and Adaptated Land
> Use (WASCAL)
> Center for Development Research (ZEF) - University of Bonn
> email : ahmadou.dicko at ucad.edu.sn <mailto:ahmadou.dicko at ucad.edu.sn>
> twitter : @dickoah
> github : github/dickoa <https://github.com/dickoa>
> tel : +221 33 827 55 16
> portable: +221 77 123 81 69
Edzer Pebesma
Institute for Geoinformatics, University of Münster,
Heisenbergstraße 2, 48149 Münster, Germany; +49 251 83 33081
Journal of Statistical Software:   http://www.jstatsoft.org/
Computers & Geosciences: http://elsevier.com/locate/inca/398
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20150212/40407a91/attachment.pgp>
More information about the grass-stats mailing list
