[GRASS-stats] spgrass7 support for strds?
Rainer M Krug Rainer at krugs.de
Fri Feb 20 01:35:10 PST 2015
Roger Bivand <Roger.Bivand at nhh.no> writes:
> I've committed "rgrass7" for the next package, leaving the others as
> they are. I'll try to submit by the end of the month.
Thanks a lot Roger.
Looking forward of seeing it on CRAN,
Rainer
> Roger
> On Thu, 12 Feb 2015, Rainer M Krug wrote:
>> Just for clarification - the rgrass solution would mean:
>> GRASS    for GRASS 5
>> spgrass6 for GRASS 6
>> rgrass   for GRASS 7
>> If this is correct, then it is very confusing.
>> To re-iterate:
>> I like the rgrass, but
>> rgrass6 and rgrass7
>> would make things clearer.
>> Rainer
>> Edzer Pebesma <edzer.pebesma at uni-muenster.de> writes:
>>> I'm in favour of rgrass.
>>> On 02/12/2015 12:13 PM, Ahmadou Dicko wrote:
>>>> I will also cast my vote in favor of 'rgrass' because of the consistency
>>>> with other library and gis linked to R (RSAGA, rgeos, rgdal, etc.).
>>>> We can just then make sure that it works with both version of GRASS (6
>>>> and 7).
>>>> I also started a project (idea) a long time ago with Rainer to have
>>>> something similar to pygrass[1] in R through Rcpp
>>>> (https://github.com/RGRASS/grassRLink) in order to access the low level
>>>> GRASS API.
>>>> I didn't have time to finish it but I will have more time this summer
>>>> and hope to work on it again.
>>>> I think it can be a good idea of GSOC for either GRASS or R.
>>>> [1]: http://grasswiki.osgeo.org/wiki/Python/pygrass
>>>> On Thu, Feb 12, 2015 at 10:51 AM, Rainer M Krug <Rainer at krugs.de
>>>> <mailto:Rainer at krugs.de>> wrote:
>>>>     Roger Bivand <Roger.Bivand at nhh.no <mailto:Roger.Bivand at nhh.no>> writes:
>>>>    > Question further down ...
>>>>    > On Wed, 11 Feb 2015, Edzer Pebesma wrote:
>>>>     <mailto:edzer.pebesma at uni-muenster.de>> writes:
>>>>    >>>>>> Since I'm uncertain whether the maintainer of spacetime is on
>>>>     this
>>>>    >>>>>> list, I'm CC-ing him here. It might make sense to discuss this -
>>>>    >>>>>> perhaps spgrass7 in the R-forge spgrass project is a logical
>>>>     place to
>>>>    >>>>>> support these functions?
>>>>    >>>>> It is a brilliant idea to support spatio-temporal data in the
>>>>     spgrass7
>>>>    >>>>> framework.
>>>>    >>>>> I agree that the functions should be in spgrass7 and that they
>>>>     should
>>>>    >>>>> have the same interface structure as the other
>>>>     read/write[RAST/VECT]
>>>>    >>>>> functions.
>>>>    >>>>> I never used the package spacetime or spatio-temporal datasets
>>>>     in GRASS,
>>>>    >>>>> but maybe these functions could be re-used (or at least parts
>>>>     of it)?
>>>>    >>>> yes; and use the TGRASS (Cc: Soeren, the author), framework. Also,
>>>>    >>>> raster stacks with time z should be of interest (Cc: Robert).
>>>>    >>> Please forgive my ignorance - but is there actually an accepted (as
>>>>    >>> SpatialGridDataFrame et al are accepted) object framework for these
>>>>    >>> spatio-temporal datasets in R? It sounds as if there is not at
>>>>     the moment?
>>>>    >> When is something accepted? raster and spacetime have both been
>>>>     on CRAN
>>>>    >> for some years, and have both been considered useful by people
>>>>    >> independent from the developers. There is a SpatioTemporal task view
>>>>    >> that tries to list everything possibly relevant.
>>>>    >>>>> But this should not hold back the release of spgrass7 in it's
>>>>     current
>>>>    >>>>> form.
>>>>    >>>> I suggest to rename this package to "grass", supporting the current
>>>>    >>>> grass release.
>>>>    >>>> Grass took 7 years to move 6 to 7; I discussed this with Markus
>>>>     last
>>>>    >>>> night, they might as well give up this crazy major version
>>>>     release cycle
>>>>    >>>> idea, with all kind of restrictions they impose on themselves.
>>>>    >>> This might cause confusion. And as long as GRASS has major
>>>>     versions, I
>>>>    >>> think we should stick with this naming scheme.
>>>>    >> We don't do this with rgdal, rgeos, RSAGA, RArcInfo, and so on.
>>>>     But many
>>>>    >> of these have an "r" in front. This seems obsolete as they are R
>>>>    >> packages, but may be helpful in sentences like "We used grass and the
>>>>    >> r-package rgrass for carrying out multidimensional scaling on the
>>>>     MODIS
>>>>    >> imagery ...", which, without the leading r, would have the word
>>>>     "grass"
>>>>    >> twice in it referring to different things.
>>>>    >> spgrass has sp in it for historic reasons - we thought about
>>>>     prefixing
>>>>    >> everything with sp in the early sp days. Now sp is default, and one
>>>>    >> could think about a better name.
>>>>    > OK, I think we keep (archived) "GRASS" for the interface to GRASS 5,
>>>>    > "spgrass6" for GRASS 6. As of now, we've called the development
>>>>    > version "spgrass7", but arguably "rgrass" could be preferred. As GRASS
>>>>    > 7 is due on Sunday, could I ask for a quick show of hands on
>>>>    > "spgrass7" or "rgrass" as the name for the package to be submitted to
>>>>    > CRAN (tomorrow)? We can continue to consider moving spacetime code to
>>>>    > this package, but we should have the new package on CRAN matching the
>>>>    > release of GRASS 7.
>>>>     The r in front makes sense - but if one looks at the changes in the
>>>>     interface between GRASS 6 and GRASS 7 I would keep the 7 - so I would
>>>>     suggest
>>>>     rgrass7
>>>>     and possibly also release the (modified) spgrass6 as rgrass6, and leave
>>>>     spgrass6 there for compatibility, and give a warning upon load that the
>>>>     package has been superseded by rgrass6.
>>>>     This also opens the possibility of releasing a package called
>>>>     rgrass
>>>>     which then, depending on the GRASS version loaded / requested loads the
>>>>     corresponding rgrassX package.
>>>>     Rainer
>>>>    > Roger
>>>>    >>> Cheers,
>>>>    >>> Rainer
>>>>    >>>>> Cheers,
>>>>    >>>>> Rainer
>>>>    >>>>>> Roger
>>>>    >>>>>> On Wed, 11 Feb 2015, Veronica Andreo wrote:
>>>>    >>>>>>> Hi
>>>>    >>>>>>> Since you are discussing the new spgrass for GRASS 7 (and since GRASS 7
>>>>    >>>>>>> includes these great temporal modules), I was wondering if there's any
>>>>    >>>>>>> chance to include support for reading/writing spatio-temporal data sets.
>>>>    >>>>>>> At present, there are two functions in spacetime package (read.tgrass and
>>>>    >>>>>>> write.tgrass) that allows reading and writing strds, but you need to export
>>>>    >>>>>>> it from GRASS first, do the R processing you need, and then, import it back
>>>>    >>>>>>> into GRASS. To have something a bit more straightforward would be awesome!
>>>>    >>>>>>> I don't know how complicated this could be, that's why I dare to ask :)
>>>>    >>>>>>> Keep the great job you are doing!!! And thanks a lot!!!
>>>>    >>>>>>> Cheers,
>>>>    >>>>>>> Vero
>>>>    >>>>> _______________________________________________
>>>>    >>>>> grass-stats mailing list
>>>>    >>>>> grass-stats at lists.osgeo.org <mailto:grass-stats at lists.osgeo.org>
>>>>    >>>>> http://lists.osgeo.org/mailman/listinfo/grass-stats
>>>>     Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
>>>>     Biology, UCT), Dipl. Phys. (Germany)
>>>>     Centre of Excellence for Invasion Biology
>>>>     Stellenbosch University
>>>>     South Africa
>>>>     Tel :       +33 - (0)9 53 10 27 44
>>>>     <tel:%2B33%20-%20%280%299%2053%2010%2027%2044>
>>>>     Cell:       +33 - (0)6 85 62 59 98
>>>>     <tel:%2B33%20-%20%280%296%2085%2062%2059%2098>
>>>>     Fax :       +33 - (0)9 58 10 27 44
>>>>     <tel:%2B33%20-%20%280%299%2058%2010%2027%2044>
>>>>     Fax (D):    +49 - (0)3 21 21 25 22 44
>>>>     <tel:%2B49%20-%20%280%293%2021%2021%2025%2022%2044>
>>>>     email:      Rainer at krugs.de <mailto:Rainer at krugs.de>
>>>>     Skype:      RMkrug
>>>>     PGP: 0x0F52F982
>>>> Ahmadou H. DICKO
>>>> statistician economist (Ingénieur Statisticien Économiste)
>>>> PhD candidate in Climate change economics
>>>> Faculty of economics and managment - Cheikh Anta Diop University
>>>> West African Science Service Center on Climate Change and Adaptated Land
>>>> Use (WASCAL)
>>>> Center for Development Research (ZEF) - University of Bonn
>>>> email : ahmadou.dicko at ucad.edu.sn <mailto:ahmadou.dicko at ucad.edu.sn>
>>>> twitter : @dickoah
>>>> github : github/dickoa <https://github.com/dickoa>
>>>> tel : +221 33 827 55 16
>>>> portable: +221 77 123 81 69
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
South Africa
Skype:      RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20150220/48a5e141/attachment.pgp>
More information about the grass-stats mailing list
