[GRASS-stats] v.isochrones in spgrass7
yogeshbansal mryogeshbansal at live.com
Sun Mar 15 08:34:32 PDT 2015
Hi everyone,
I am able to use the v.isochrones addon in GRASS7. But if i try to use the
v.isochrones command by wrapping it in execGRASS() it says the
v.iochrones.exe doesn't exist. I checked the issue and what i could
understand is the v.isochrones addon is run directly using it's python
scritp and a .exe file for same is not stored when i install this addon.
So is there any way i can use the v.isochrones from inside R using spgrass7
package?
Thanks in advance.
Regards
Yogesh Bansal
View this message in context: http://osgeo-org.1560.x6.nabble.com/v-isochrones-in-spgrass7-tp5193445.html
Sent from the Grass - Stats mailing list archive at Nabble.com.
More information about the grass-stats mailing list
