[GRASS-stats] rgrass7 read/write SpatialPolygonsDataFrames errors
Roger Bivand Roger.Bivand at nhh.no
Sat Oct 10 06:56:22 PDT 2015
OK, thanks. So the failure is in:
vinfo0 <- execGRASS("v.info", flags="c", map="<name>", layer=1L,
   intern=TRUE)
used to return the column/field names. Please repeat with that.
Roger
On Fri, 9 Oct 2015, Eduardo Diez wrote:
> Here are the traceback and the vInfo(zm.gnrl). The latter seems to work
> fine.
>> zm.fnl <- readVECT(zm.gnrl)
> Error in scan(file, what, nmax, sep, dec, quote, skip, nlines, na.strings,
>  line 4 did not have 2 elements
>> traceback()
> 8: scan(file = file, what = what, sep = sep, quote = quote, dec = dec,
>       nmax = nrows, skip = 0, na.strings = na.strings, quiet = TRUE,
>       fill = fill, strip.white = strip.white, blank.lines.skip =
> blank.lines.skip,
>       multi.line = FALSE, comment.char = comment.char, allowEscapes =
> allowEscapes,
>       flush = flush, encoding = encoding, skipNul = skipNul)
> 7: read.table(con, header = FALSE, sep = "|")
> 6: vColumns(vname)
> 5: nchar(as.character(vColumns(vname)$name))
> 4: .read_vect_non_plugin(vname = vname, layer = layer, type = type,
>       remove.duplicates = remove.duplicates, ignore.stderr =
> ignore.stderr,
>       pointDropZ = pointDropZ, driver = driver, with_prj = with_prj,
>       with_c = with_c)
> 3: tryCatchList(expr, classes, parentenv, handlers)
> 2: tryCatch({
>       stopifnot(is.logical(plugin) || is.null(plugin))
>       stopifnot(is.logical(ignore.stderr))
>       if (missing(layer))
>           layer <- 1L
>       layer <- as.character(layer)
>       stopifnot(is.logical(with_c))
>       if (!is.null(driver) && driver == "GRASS")
>           plugin <- TRUE
>       if (!requireNamespace("rgdal", quietly = TRUE)) {
>           stop("rgdal not available")
>       if (is.null(plugin)) {
>           ogrD <- rgdal::ogrDrivers()$name
>           plugin <- "GRASS" %in% ogrD
>       if (plugin) {
>           res <- .read_vect_plugin(vname = vname, layer = layer,
>               type = type, ignore.stderr = ignore.stderr, pointDropZ =
> pointDropZ,
>               mapset = mapset)
>       else {
>           res <- .read_vect_non_plugin(vname = vname, layer = layer,
>               type = type, remove.duplicates = remove.duplicates,
>               ignore.stderr = ignore.stderr, pointDropZ = pointDropZ,
>               driver = driver, with_prj = with_prj, with_c = with_c)
>   }, finally = {
>       if (get.suppressEchoCmdInFuncOption()) {
>           tull <- set.echoCmdOption(inEchoCmd)
> 1: readVECT(zm.gnrl)
>> vInfo(zm.gnrl)
>     nodes     points      lines boundaries  centroids      areas
> islands primitives      map3d
>       274          0          0        302         31         31
> 3        333          0
> Thanks
> 2015-10-09 11:36 GMT-03:00 Roger Bivand <Roger.Bivand at nhh.no>:
>> If it is the v.info call, please run:
>> res <- execGRASS("v.info", flags="t", map="zm.gnrl", layer=1L,
>> intern=TRUE)
>> and report the output of:
>> print(res)
>> and maybe send me offlist the output of
>> save(res, file="vinfo_odd_output.RData")
>> Roger
>> Roger Bivand
>> Norwegian School of Economics
>> Helleveien 30, 5045 Bergen, Norway
>> ________________________________________
>> Fra: grass-stats [grass-stats-bounces at lists.osgeo.org] på vegne av
>> Roger Bivand [Roger.Bivand at nhh.no]
>> Sendt: 9. oktober 2015 4:27
>> Til: Eduardo Diez
>> Kopi: grass-stats at lists.osgeo.org
>> Emne: Re: [GRASS-stats] rgrass7 read/write SpatialPolygonsDataFrames errors
>> OK, please provide the output of traceback() run immediately after the
>> failing readVECT(). That will show which command invokes scan(). Also try
>> to run vInfo(zm.gnrl) - I think the failure is in:
>> execGRASS("v.info", flags="t", map="zm.gnrl", layer=1L)
>> not returning a structure that vInfo understands, and which ois then used
>> in readVECT().
>> Roger
>> Roger Bivand
>> Fra: diez.edu at gmail.com [diez.edu at gmail.com] på vegne av Eduardo Diez [
>> eduardodiez at gmx.com]
>> Sendt: 9. oktober 2015 4:04
>> Til: Roger Bivand
>> Roger, with GRASS version 7.0.1 and rgrass7_0.1-3, readVECT now doesn't
>> ask for the driver to use but gives the same error as before:
>> writeVECT(SDF = mz.pol, vname = zm.pol, v.in.ogr_flags = "o")
>> Over-riding projection check
>> Check if OGR layer <q7468fb> contains polygons...
>> Importing 205 features (OGR layer <q7468fb>)...
>> Registering primitives...
>> 3924 primitives registered
>> 12866 vertices registered
>> Number of nodes: 2884
>> Number of primitives: 3924
>> Number of points: 0
>> Number of lines: 0
>> Number of boundaries: 3924
>> Number of centroids: 0
>> Number of areas: -
>> Number of isles: -
>> Cleaning polygons
>> Breaking polygons...
>> Breaking polygons (pass 1: select break points)...
>> Breaking polygons (pass 2: break at selected points)...
>> Removing duplicates...
>> Breaking boundaries...
>> Cleaning boundaries at nodes...
>> Merging boundaries...
>> Removing dangles...
>> Building areas...
>> 205 areas built
>> 13 isles built
>> Number of nodes: 2929
>> Number of primitives: 7268
>> Number of points: 0
>> Number of lines: 0
>> Number of boundaries: 7268
>> Number of areas: 205
>> Number of isles: 13
>> Removing bridges...
>> 498 primitives registered
>> 5828 vertices registered
>> Building areas...
>> 205 areas built
>> 13 isles built
>> Attaching islands...
>> Number of nodes: 306
>> Number of primitives: 498
>> Number of points: 0
>> Number of lines: 0
>> Number of boundaries: 498
>> Number of isles: 13
>> Finding centroids for OGR layer <q7468fb>...
>> Writing centroids...
>> 205 input polygons
>> Total area: 1.25187E+006 (205 areas)
>> Copying features...
>> WARNING: Unable to delete file
>>  'C:/Users/ediez1/AppData/Local/Temp/Rtmpqkeay4/file480c1e5e16a7/file480c11cc233b/.tmp/unknown/vector/tmp_8308/coor'
>> Building topology for vector map <q7468fb at file480c11cc233b>...
>> 703 primitives registered
>> 6033 vertices registered
>> Building areas...
>> 205 areas built
>> 13 isles built
>> Attaching centroids...
>> Number of primitives: 703
>> Number of points: 0
>> Number of lines: 0
>> Number of centroids: 205
>> Number of isles: 13
>>> execGRASS("v.clean", flags = c("overwrite"), input = zm.pol,
>> + output = zm.gnrl, tool = "rmarea", threshold = 3000)
>> Tool: Threshold
>> Remove small areas: 3000
>> Copying features...
>> Rebuilding parts of topology...
>> Building topology for vector map <u10f44b at file480c11cc233b>...
>> Building areas...
>> 205 areas built
>> 13 isles built
>> Number of points: 0
>> Number of lines: 0
>> Number of isles: 13
>> Tool: Remove small areas
>> 174 areas of total size 50601.7 removed
>> Rebuilding topology for output vector map...
>> 333 primitives registered
>> 4705 vertices registered
>> Building areas...
>> 31 areas built
>> 3 isles built
>> Number of nodes: 274
>> Number of primitives: 333
>> Number of points: 0
>> Number of lines: 0
>> Number of boundaries: 302
>> Number of centroids: 31
>> Number of areas: 31
>> Number of isles: 3
>> na.strings,  :
>>> sessionInfo()
>> R version 3.2.2 (2015-08-14)
>> Platform: x86_64-w64-mingw32/x64 (64-bit)
>> Running under: Windows 7 x64 (build 7601) Service Pack 1
>> locale:
>> [1] LC_COLLATE=English_United States.1252  LC_CTYPE=English_United
>> States.1252    LC_MONETARY=English_United States.1252
>> [4] LC_NUMERIC=C                           LC_TIME=English_United
>> States.1252
>> attached base packages:
>> [1] stats     graphics  grDevices utils     datasets  methods   base
>> other attached packages:
>>  [1] RPyGeo_0.9-3    RSAGA_0.94-3    plyr_1.8.3      gstat_1.0-26
>> shapefiles_0.7  foreign_0.8-65  maptools_0.8-37 rgdal_1.0-7
>>  classInt_0.1-23
>> [10] raster_2.4-20   rgrass7_0.1-3   XML_3.98-1.3    sp_1.2-0
>> loaded via a namespace (and not attached):
>>  [1] Rcpp_0.12.1      intervals_0.15.1 lattice_0.20-33  FNN_1.1
>> spacetime_1.1-4  class_7.3-13     zoo_1.7-12       grid_3.2.2
>>  [9] e1071_1.6-7      xts_0.9-7        tools_3.2.2
>> Thanks
>> 2015-10-08 18:57 GMT-03:00 Roger Bivand
>> Sorry this has taken a long time; please try installing the development
>> version available from:
>> http://win-builder.r-project.org/8Y3Ihj451Clx
>> (rgrass7_0.1-3.zip). The problem was the use of "_" instead of " " in the
>> name of the OGR shapefile driver - in OGR and R it is "ESRI Shapefile", in
>> GRASS it is "ESRI_Shapefile". Because the new long-name work-around worked
>> on systems not needing to use this
>>  driver, it wasn't properly tested - and on Windows the GRASS standalone
>> has OGR with the SQLite driver, but the Windows rgdal binary does not have
>> SQLite. You may wish to install the R RSQLite package to move data if you
>> use long field/column names.
>> Before installing this development version, and after library(rgrass7),
>> run example(readVECT) in the basic nc location from:
>> https://grass.osgeo.org/sampledata/north_carolina/nc_basic_spm_grass7.zip
>> it should fail. Then restart R, install the development version of rgrass7
>> from the first link, and repeat - it works for me and should resolve the
>> problem.
>> Hope this helps,
>> Roger
>> Roger Bivand
>> Fra:
>> grass-stats-bounces at lists.osgeo.org [grass-stats-bounces at lists.osgeo.org]
>>  på vegne av Eduardo Diez [eduardodiez at gmx.com]
>> Sendt: 24. september 2015 9:11
>> Til:
>> Emne: [GRASS-stats] rgrass7 read/write SpatialPolygonsDataFrames errors
>> Hi, I'm a user of R mostly for spatial information processing. Besides sp,
>> maptools, etc. i also use functions from GRASS, at first through spgrass6
>> and then rgrass7. A few days ago, I started having trouble reading and
>> writing SpatialPolygonsDataFrames using
>>  readVECT and writeVECT. I tried both reinstalling both grass (6.4.4,
>> 7.0.0 and 7.0.1) and the R packages (spgrass6 0.8-6 and rgrass7 0.1-2), and
>> also with different R objects but i kept getting the same errors.
>> The "mult.r" object is a RasterLayer with 4 zones and the objective is to
>> convert it to polygons and "clean" small areas with v.clean rmarea (as i
>> don't currently know a way of doing this in plain R).
>> The first thing that came out strange was that when executing writeVECT it
>> would ask me for the driver to use (in the way of rgdal's writeOGR, it
>> didn't ask for it before). I figured out that object to be written should
>> be projected (not in lat-lon, don't know
>>  why). After doing this i could write the vector and execute v.clean. The
>> problem came again when trying to read the cleaned polygons back to R.
>> Below i paste an extract of my R console with the errors and some
>> information.
>> Thanks in advance,
>> Eduardo
>>> mult.rp <- projectRaster(mult.r, crs = prj.crs, method = "ngb")
>>> mult.pol <- rasterToPolygons(mult.rp, dissolve = T)
>>> initGRASS(gisBase = "c:/Program Files (x86)/GRASS GIS 7.0.1", home =
>> tempdir(), override = T)
>> gisdbase    C:/Users/ediez1/AppData/Local/Temp/RtmpegbyiQ
>> location    file2f7c6dc070e6
>> mapset      file2f7c30eb3f52
>> rows        1
>> columns     1
>> north       1
>> south       0
>> west        0
>> east        1
>> nsres       1
>> ewres       1
>> projection  NA
>>> writeVECT(mult.pol, "pol1", v.in.ogr_flags = "o")
>> Error: !is.null(driver) is not TRUE
>>> writeVECT(mult.pol, "pol1", v.in.ogr_flags = "o", driver = "ESRI
>> Shapefile")
>> Check if OGR layer <r848659> contains polygons...
>> Importing 4 features (OGR layer <r848659>)...
>> 3005 primitives registered
>> 15587 vertices registered
>> Number of nodes: 2691
>> Number of primitives: 3005
>> Number of points: 0
>> Number of lines: 0
>> Number of boundaries: 3005
>> Number of areas: -
>> Number of isles: -
>> Cleaning polygons
>> Removing dangles...
>> Building areas...
>> 95 areas built
>> 8 isles built
>> Number of nodes: 2771
>> Number of primitives: 7307
>> Number of points: 0
>> Number of lines: 0
>> Number of boundaries: 7307
>> Number of areas: 95
>> Number of isles: 8
>> Removing bridges...
>> 231 primitives registered
>> 7594 vertices registered
>> Building areas...
>> 95 areas built
>> 8 isles built
>> Number of nodes: 144
>> Number of primitives: 231
>> Number of points: 0
>> Number of lines: 0
>> Number of boundaries: 231
>> Number of areas: 95
>> Number of isles: 8
>> Finding centroids for OGR layer <r848659>...
>> 95 input polygons
>> Total area: 1.28981E+006 (95 areas)
>> Copying features...
>>  'C:/Users/ediez1/AppData/Local/Temp/Rtmpg10lvi/filec2473b0126/filec24129b63ac/.tmp/unknown/vector/tmp_10484/coor'
>> Building topology for vector map <r848659 at filec24129b63ac>...
>> 326 primitives registered
>> 7689 vertices registered
>> Building areas...
>> 95 areas built
>> 8 isles built
>> Number of primitives: 326
>> Number of points: 0
>> Number of lines: 0
>> Number of centroids: 95
>> Number of areas: 95
>> Number of isles: 8
>>> execGRASS("v.clean", flags = c("overwrite"), input = "pol1",
>> + output = "clnpol", tool = "rmarea", threshold = 3000)
>> Tool: Threshold
>> Copying features...
>> Building topology for vector map <k1f9f75 at filec24129b63ac>...
>> Building areas...
>> 95 areas built
>> 8 isles built
>> Number of points: 0
>> Number of lines: 0
>> Number of areas: 95
>> Number of isles: 8
>> 55 areas of total size 29487.1 removed
>> 212 primitives registered
>> 6840 vertices registered
>> Building areas...
>> 40 areas built
>> 4 isles built
>> Number of nodes: 136
>> Number of primitives: 212
>> Number of points: 0
>> Number of lines: 0
>> Number of boundaries: 172
>> Number of centroids: 40
>> Number of areas: 40
>> Number of isles: 4
>>> cln.pol <- readVECT("clnpol")
>>> cln.pol <- readVECT("clnpol", driver = "ESRI Shapefile")
>> na.strings,  :
>>> sessionInfo()
>> locale:
>> States.1252
>> [1] rgrass7_0.1-2   classInt_0.1-22 maptools_0.8-36 ggplot2_1.0.1
>>  XML_3.98-1.3    raster_2.4-20   sp_1.2-0
>>  [1] Rcpp_0.12.1      magrittr_1.5     MASS_7.3-43      munsell_0.4.2
>> colorspace_1.2-6 lattice_0.20-33  stringr_1.0.0    plyr_1.8.3
>>  [9] tools_3.2.2      parallel_3.2.2   rgdal_1.0-7      grid_3.2.2
>>  gtable_0.1.2     e1071_1.6-7      class_7.3-13     rgeos_0.3-12
>> [17] digest_0.6.8     reshape2_1.4.1   labeling_0.3     stringi_0.5-5
>> scales_0.3.0     foreign_0.8-65   proto_0.3-10
>> grass-stats mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-stats
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 91 00
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
