[GRASS-stats] Using GRASS addons in R on Windows
Helmut Kudrnovsky hellik at web.de
Tue Jan 12 01:50:12 PST 2016
>OK. Please check that r.roughness.vector.bat is present in:
>C:\Users\xy\AppData\Roaming\GRASS7\addons\bin, or
>C:\Program Files\GRASS GIS 7.1.svn\bin
it is in the addon path: C:\Users\xxx\AppData\Roaming\GRASS7\addons\bin
it works in winGRASS itself.
r.roughness.vector elevation=elevation at PERMANENT slope=slope at rtestw64bit
aspect=aspect at rtestw64bit
Check if input files exist ...
Define default output names when not defined by user ...
Calculate compass aspect values ...
Calculate colatitude ...
Calculate direction cosines ...
Calculate sum of direction cosines ...
Calculating sum of X direction cosines ...
Calculating sum of Y direction cosines ...
Calculating sum of Z direction cosines ...
Calculate vector strength ...
Calculate inverted Fisher's K parameter ...
Result maps:
elevation_vector_strength_3x3
elevation_fisher_1K_3x3
Calculations done.
(Tue Jan 12 10:41:00 2016) Command finished (1 min 18 sec)
xml1.R
"            WN_bat <- sub(".bat", "",
                list.files(paste(Sys.getenv("GISBASE"), "bin", sep="/"),
                pattern=".bat$"))
            if (nchar(Sys.getenv("GRASS_ADDON_BASE")) > 0) {
                t0 <- try(sub(".bat", "",
                   list.files(paste(Sys.getenv("GRASS_ADDON_BASE"),
                       "bin", sep="/"), pattern=".bat$")), silent=TRUE)
                if (class(t0) != "try-error" && is.character(t0) &&
                   nchar(t0) > 0)
                   WN_bat <- c(WN_bat, t0)
                assign("WN_bat", WN_bat, envir=.GRASS_CACHE)
do it manually:
WN_bat <- sub(".bat", "", list.files(paste(Sys.getenv("GISBASE"), "bin",
> WN_bat
  [1] "d.correlate"          "d.frame"              "d.out.file"
  [4] "d.polar"              "d.rast.edit"          "d.rast.leg"
  [7] "d.redraw"             "d.shade"              "d.to.rast"
 [10] "d.what.rast"          "d.what.vect"          "db.dropcolumn"
 [13] "db.droptable"         "db.in.ogr"            "db.out.ogr"
 [16] "db.test"              "db.univar"            "g.extension.all"
 [19] "g.extension"          "g.gui.animation"      "g.gui.datacatalog"
 [22] "g.gui.dbmgr"          "g.gui.gcp"            "g.gui.gmodeler"
 [25] "g.gui.iclass"         "g.gui.mapswipe"       "g.gui.psmap"
 [28] "g.gui.rlisetup"       "g.gui.timeline"       "g.gui.tplot"
 [31] "g.gui.vdigit"         "g.manual"             "g.search.modules"
 [34] "i.colors.enhance"     "i.image.mosaic"       "i.in.spotvgt"
 [37] "i.oif"                "i.pansharpen"         "i.spectral"
 [40] "i.tasscap"            "m.proj"               "r.blend"
 [43] "r.buffer.lowmem"      "r.colors.stddev"      "r.fillnulls"
 [46] "r.grow"               "r.import"             "r.in.aster"
 [49] "r.in.srtm"            "r.in.wms"             "r.mask"
 [52] "r.out.xyz"            "r.pack"               "r.plane"
 [55] "r.reclass.area"       "r.rgb"                "r.shade"
 [58] "r.tileset"            "r.unpack"             "r3.in.xyz"
 [61] "t.create"             "t.info"               "t.list"
 [64] "t.merge"              "t.rast.accdetect"     "t.rast.accumulate"
 [67] "t.rast.aggregate"     "t.rast.aggregate.ds"  "t.rast.algebra"
 [70] "t.rast.colors"        "t.rast.contour"       "t.rast.export"
 [73] "t.rast.extract"       "t.rast.gapfill"       "t.rast.import"
 [76] "t.rast.list"          "t.rast.mapcalc"       "t.rast.neighbors"
 [79] "t.rast.out.vtk"       "t.rast.series"        "t.rast.to.rast3"
 [82] "t.rast.to.vect"       "t.rast.univar"        "t.rast.what"
 [85] "t.rast3d.algebra"     "t.rast3d.extract"     "t.rast3d.list"
 [88] "t.rast3d.mapcalc"     "t.rast3d.univar"      "t.register"
 [91] "t.remove"             "t.rename"             "t.sample"
 [94] "t.select"             "t.shift"              "t.snap"
 [97] "t.support"            "t.topology"           "t.unregister"
[100] "t.vect.algebra"       "t.vect.db.select"     "t.vect.export"
[103] "t.vect.extract"       "t.vect.import"        "t.vect.list"
[106] "t.vect.observe.strds" "t.vect.univar"        "t.vect.what.strds"
[109] "v.build.all"          "v.centroids"          "v.db.addcolumn"
[112] "v.db.addtable"        "v.db.dropcolumn"      "v.db.droprow"
[115] "v.db.droptable"       "v.db.join"            "v.db.reconnect.all"
[118] "v.db.renamecolumn"    "v.db.univar"          "v.db.update"
[121] "v.dissolve"           "v.import"             "v.in.e00"
[124] "v.in.geonames"        "v.in.lines"           "v.in.mapgen"
[127] "v.in.wfs"             "v.krige"              "v.pack"
[130] "v.rast.stats"         "v.report"             "v.to.lines"
[133] "v.unpack"             "v.what.strds"         "v.what.vect"
[136] "wxpyimgview"
t0 <- sub(".bat", "", list.files(paste(Sys.getenv("GRASS_ADDON_BASE"),
> t0
 [1] "m.ecad"                "r.basin"               "r.biodiversity"
 [4] "r.euroeco"             "r.hypso"               "r.roughness.vector"
 [7] "r.sun.daily"           "r.sun.hourly"          "r.width.funct"
[10] "v.fixed.segmentpoints" "v.in.gbif"             "v.in.natura2000"
[13] "v.in.redlist"          "v.stats"
> WN_bat
[136] "wxpyimgview"           "m.ecad"                "r.basin"
[139] "r.biodiversity"        "r.euroeco"             "r.hypso"
[142] "r.roughness.vector"    "r.sun.daily"           "r.sun.hourly"
[145] "r.width.funct"         "v.fixed.segmentpoints" "v.in.gbif"
[148] "v.in.natura2000"       "v.in.redlist"          "v.stats"
r.roughness.vector is in the list of the script related bat-files.
>Possibly run
>debug(parseGRASS)
>parseGRASS("r.roughness.vector")
debug.txt <http://osgeo-org.1560.x6.nabble.com/file/n5244663/debug.txt>
attached.
the last lines of debug:
Browse[2]>
debug: tr <- try(system(cmd0, intern = TRUE))
Browse[2]>
Error in system(cmd0, intern = TRUE) : 'r.roughness.vector.exe' not found
debug: if (class(tr) == "try-error") stop(paste(cmd, "not found"))
Browse[2]>
Browse[2]>
debug: stop(paste(cmd, "not found"))
Browse[2]>
Browse[2]>
Error in parseGRASS("r.roughness.vector") : r.roughness.vector not found
here on my side for addon scripts but also for GRASS own scripts it seems to
append an .exe instead of .bat (see above); but I can't find this in the
rgarss7 code.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Using-GRASS-addons-in-R-on-Windows-tp5244411p5244663.html
Sent from the Grass - Stats mailing list archive at Nabble.com.
More information about the grass-stats mailing list
