[GRASS-stats] Using GRASS addons in R on Windows
Helmut Kudrnovsky hellik at web.de
Wed Jan 13 05:26:25 PST 2016
>http://win-builder.r-project.org/KJJJkeazt7Sw/rgrass7_0.1-5.zip
>Could users of initGRASS() please check that the environment variables are
>set correctly for addons?
> sessionInfo()
R version 3.2.3 (2015-12-10)
Platform: x86_64-w64-mingw32/x64 (64-bit)
Running under: Windows 7 x64 (build 7601) Service Pack 1
locale:
[1] LC_COLLATE=German_Austria.1252  LC_CTYPE=German_Austria.1252
LC_MONETARY=German_Austria.1252 LC_NUMERIC=C
[5] LC_TIME=German_Austria.1252
attached base packages:
[1] stats     graphics  grDevices utils     datasets  methods   base
other attached packages:
[1] rgrass7_0.1-5 XML_3.98-1.3  sp_1.2-2
loaded via a namespace (and not attached):
[1] grid_3.2.3      lattice_0.20-33
> library(rgrass7)
Lade nötiges Paket: sp
Lade nötiges Paket: XML
GRASS GIS interface loaded with GRASS version: (GRASS not running)
> initGRASS("C:/Program Files/GRASS GIS 7.1.svn", home=tempdir(),
> gisDbase="C:/grassdata", location="nc_spm_08", mapset="user1")
gisdbase    C:/grassdata
location    nc_spm_08
mapset      user1
rows        6
columns     8
north       222800
south       222740
west        642590
east        642670
nsres       10
ewres       10
projection  +proj=lcc +lat_1=36.16666666666666 +lat_2=34.33333333333334
+lat_0=33.75 +lon_0=-79 +x_0=609601.22 +y_0=0 +no_defs +a=6378137
+rf=298.257222101 +towgs84=0.000,0.000,0.000 +to_meter=1
> execGRASS("g.region", raster="elevation", align="elevation", flags="a")
> execGRASS("r.slope.aspect", elevation="elevation", slope="myslope",
> aspect="myaspect")
Expositions-Rasterkarte <myaspect> komplett.
Neigungs-Rasterkarte <myslope> komplett.
> execGRASS("r.roughness.vector", elevation="elevation", slope="myslope",
> aspect="myaspect", strength="vectorstrength")
Check if input files exist ...
Define default output names when not defined by user ...
Calculate compass aspect values ...
Calculate colatitude ...
Calculate direction cosines ...
Calculate sum of direction cosines ...
Calculating sum of X direction cosines ...
Calculating sum of Y direction cosines ...
Calculating sum of Z direction cosines ...
Calculate vector strength ...
Calculate inverted Fisher's K parameter ...
Result maps:
vectorstrength
elevation_fisher_1K_3x3
Calculations done.
> execGRASS("r.reclass.area", input="zipcodes",
> output="zipcode_larger2000ha", value=2000, mode="greater")
Generating a clumped raster file ...
Pass 1 of 2...
Generating renumbering scheme...
Pass 2 of 2...
r.clump komplett. 16 clumps.
Generating a reclass map with area size greater than or equal to
2000.000000 hectares...
Generating output raster map <zipcode_larger2000ha>...
it seems to work properly in:
R version 3.2.3 (2015-12-10) -- "Wooden Christmas-Tree"
Copyright (C) 2015 The R Foundation for Statistical Computing
thanks!
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Using-GRASS-addons-in-R-on-Windows-tp5244411p5244989.html
Sent from the Grass - Stats mailing list archive at Nabble.com.
More information about the grass-stats mailing list
