[GRASS-stats] R 3.3.1 and GRASSGIS 7.0.4
Helmut Kudrnovsky hellik at web.de
Thu Jul 14 12:50:07 PDT 2016
C. Buerger IV wrote
>>When you launch Rscript from GRASS terminal (the black one) what do you
get?
> The same error as before.
here on my side:
Cleaning up temporary files...
Starting GRASS GIS...
WARNUNG: Sperren gleichzeitiger Zugriffe auf ein Mapset ist unter Windows
         nicht möglich.
          __________  ___   __________    _______________
         / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
        / / __/ /_/ / /| | \__ \\_  \   / / __ / / \__ \
       / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
       \____/_/ |_/_/  |_/____/____/   \____/___//____/
Welcome to GRASS GIS 7.3.svn (r68855)
GRASS GIS homepage:                      http://grass.osgeo.org
This version running through:            Command Shell
(C:\Windows\system32\cmd.exe)
Help is available with the command:      g.manual -i
See the licence terms with:              g.version -c
See citation options with:               g.version -x
If required, restart the GUI with:       g.gui wxpython
When ready to quit enter:                exit
Launching <wxpython> GUI in the background, please wait...
Microsoft Windows [Version 10.0.10586]
(c) 2015 Microsoft Corporation. Alle Rechte vorbehalten.
C:\Users\xxx>Rscript
Usage: /path/to/Rscript [--options] [-e expr [-e expr2 ...] | file] [args]
so we maybe narrow down the problem.
here on my side Rscript.exe lives in :
C:\Program Files\R\R-3.3.1\bin
can you have a look at it if the exe is there?
and start a normal windows console, just the one which is delivered by
windows itself and type RScript
here on my side:
C:\Users\xxxx>cd C:\Program Files\R\R-3.3.1\bin
C:\Program Files\R\R-3.3.1\bin>RScript
--options accepted are
  --help              Print usage and exit
  --version           Print version and exit
  --verbose           Print information on progress
  --default-packages=list
                      Where 'list' is a comma-separated set
                        of package names, or 'NULL'
or options to R, in addition to --slave --no-restore, such as
  --save              Do save workspace at the end of the session
  --no-environ        Don't read the site and user environment files
  --no-site-file      Don't read the site-wide Rprofile
  --no-init-file      Don't read the user R profile
  --restore           Do restore previously saved objects at startup
  --vanilla           Combine --no-save, --no-restore, --no-site-file
                        --no-init-file and --no-environ
'file' may contain spaces but not shell metacharacters
Expressions (one or more '-e <expr>') may be used *instead* of 'file'
See also  ?Rscript  from within R
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/R-3-3-1-and-GRASSGIS-7-0-4-tp5274444p5276460.html
Sent from the Grass - Stats mailing list archive at Nabble.com.
More information about the grass-stats mailing list
