[GRASS-stats] GRASS can't find R packages from personal library on Windows
Roger Bivand Roger.Bivand at nhh.no
Tue Nov 15 01:04:06 PST 2016
On Tue, 15 Nov 2016, Anna Petrášová wrote:
> Hi,
> I installed latest R on fresh Windows 10, then I installed several
> packages into my personal library, then I installed standalone GRASS
> GIS 7.3, and when I run R from GRASS session, it does not see the
> installed packages. .libPaths() called from GRASS session indeed does
> not show the path to the personal library. I installed the packages
> again in GRASS session and then it's OK. Any idea why this happens and
> how to avoid that?
No idea, only you can reproduce what you are doing. Do you mean 7.3, the
development version? Try the 7.0 and 7.2 versions, and compare to see
which environment variables may not be being transferred (R_LIBS probably)
in GRASS 7.3. Are you running R in a Windows terminal (if such
exists in Windows 10) inside GRASS, or in the command line in the
GRASS GUI? If the latter, has this changed?
Roger
> Thank you,
> Anna
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-stats
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 91 00
e-mail: Roger.Bivand at nhh.no
http://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
http://depsy.org/person/434412
More information about the grass-stats mailing list
