[GRASS-stats] GRASS can't find R packages from personal library on Windows
Helmut Kudrnovsky hellik at web.de
Thu Nov 17 02:25:51 PST 2016
Helmut Kudrnovsky wrote
> Roger Bivand wrote
>> For me on Linux, R_LIBS is set by me and works, but on Windows the
>> default
>> is (possibly) set in the Registry anyway, which would/should be used if
>> R_LIBS is not set. Within R, .libPaths() should be the same inside GRASS
>> and outside GRASS. In Linux I have chosen to set R_LIBS, in Windows 7,
>> GRASS standalone 7.0.4, I can start R GUI in the GRASS GUI console
>> command
>> line, and my personal library is found (no R_LIBS set, .libPaths()
>> returns
>> the default). I haven't tried with GRASS 7.2 on Windows.
>  .libPaths() works here the same outside an inside a winGRASS session.
> everything works.
> I've installed all my libraries system wide here, not to any personal
> folder like Anna.
> so I'll test later by adding some libraries to a personal folder like
> Anna.
now tested by intalling some libraries into my personal library.
outside a winGRASS7.2.svn session
> .libPaths()
[1] "C:/Users/test/Documents/R/win-library/3.3"
[2] "C:/Program Files/R/R-3.3.1/library"
inside a winGRASS7.2.svn session
> .libPaths()
[1] "C:/Program Files/R/R-3.3.1/library"
there is a diffference between inside and outside a winGRASS7.2.svn session
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-can-t-find-R-packages-from-personal-library-on-Windows-tp5295771p5296217.html
Sent from the Grass - Stats mailing list archive at Nabble.com.
More information about the grass-stats mailing list
