[GRASS-stats] GRASS can't find R packages from personal library on Windows
Roger Bivand Roger.Bivand at nhh.no
Thu Nov 17 03:04:20 PST 2016
>> now tested by intalling some libraries into my personal library.
>> outside a winGRASS7.2.svn session
>>> .libPaths()
>> [1] "C:/Users/test/Documents/R/win-library/3.3"
>> [2] "C:/Program Files/R/R-3.3.1/library"
>> inside a winGRASS7.2.svn session
>>> .libPaths()
>> [1] "C:/Program Files/R/R-3.3.1/library"
>> there is a diffference between inside and outside a winGRASS7.2.svn
>> session
> now tested with standalone winGRASS7.0.5; same behaviour; inside a
> winGRASS-session the personal library seems not to be found.
> any idea?
My Windows 7, GRASS 7.0.4 shows identical .libPaths() values both inside
and out with RGui. I don't know how the location of the personal library
folder is recorded - is it in the registry? How might one know? It looks
like:
Sys.getenv("R_LIBS_USER")
gives a template, so maybe it isn't in the registry? Some documentation
here:
https://cran.r-project.org/bin/windows/base/rw-FAQ.html#I-don_0027t-have-permission-to-write-to-the-R_002d3_002e3_002e2_005clibrary-directory
https://cran.r-project.org/doc/manuals/r-release/R-admin.html#Windows-packages
Users can have one or more libraries, normally specified by the
environment variable R_LIBS_USER. This has a default value (to see it, use
‘Sys.getenv("R_LIBS_USER")’ within an R session), but that is only used if
the corresponding directory actually exists (which by default it will not)
https://cran.r-project.org/doc/manuals/r-release/R-admin.html#Managing-libraries
Best wishes,
Roger
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-can-t-find-R-packages-from-personal-library-on-Windows-tp5295771p5296219.html
> Sent from the Grass - Stats mailing list archive at Nabble.com.
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-stats
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 91 00
e-mail: Roger.Bivand at nhh.no
http://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
http://depsy.org/person/434412
More information about the grass-stats mailing list
